Component: Switch (Push, PCB) ()
Revision as of 15:18, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category
Switch (Push, PCB) component
Simple tactile PCB switch for PCB mounting. Approx. 12 * 12mm. Color and operation can be set from properties.
Please click here to view the component source code (Beta): FC_Comp_Source_sw_push_pcb.fcfx
Here is an example Flowcode program to read the value of a switch. FC6 Icon.png Switch
(5V / 11K) * 10K = 4.54545V
Fc9-type-5-icon.png Connection
The chip pin to which the switch connects.
Fc9-type-16-icon.png Polarity
Set the polarity of states sent to the chip pin. 'Active High' -> Pressed = On, Released = Off 'Active Low' -> Pressed = Off, Released = On
Fc9-type-14-icon.png Debounce (ms)
Sets the time in milliseconds to allow a pin change to settle into a stable state. NB) Debouncing is only used when reading the button state using the component macros. Chip pins are NOT debounced.
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Operation
Latching = Mouse click to turn on, click again to trun off. Momentary = Click to turn on, release to turn off.
Fc9-type-1-icon.png Color
Color of the key cap
