Component: Infrared Array AMG88xx (Light)
| Category | Light |
Infrared Array AMG88xx component
An 8x8 (64) Pixel infrared sensor array allowing basic none contact temperature detection.
Please click here to download the component source project: FC_Comp_Source_AMG88.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_AMG88.fcfx
|   | SetMovingAverageMode |
| Set the moving average mode on or off. | |
|  - BOOL | Mode |
| 0 = Off, 1 = On | |
|  - VOID | Return |
|   | ClearInterrupt |
| Clear any triggered interrupts | |
|  - VOID | Return |
|   | SetInterruptMode |
| Set the interrupt to either absolute value or difference mode | |
|  - BOOL | Mode |
| 0 = Difference / 1 = Absolute | |
|  - VOID | Return |
|   | SetInterrupt |
| Allows the interrupt pin to be enabled or disabled. | |
|  - BOOL | Mode |
| 0 = Disabled / 1 = Enabled | |
|  - VOID | Return |
|   | SamplePixels |
| Reads Infrared sensor values | |
|  - VOID | Return |
|   | ReadThermistor |
| Reads the onboard thermistor Returns the temperature in degrees Celsius as a floating point value | |
|  - FLOAT | Return |
|   | ReadPixel |
| Reads the temperature of a single pixel value from the last SamplePixels call. | |
|  - BYTE | Index |
| Pixel to read. Range: 0 - 63 | |
|  - FLOAT | Return |
|   | Initialise |
| Sets up the I2C interface and initialises the sensor. | |
|  - VOID | Return |
|  - BOOL | Mode |
| 0 = Off, 1 = On | |
|  - VOID | Return |
|   | ClearInterrupt |
|  - VOID | Return |
|   | SetInterruptMode |
|  - BOOL | Mode |
|  - VOID | Return |
|   | SetInterrupt |
|  - BOOL | Mode |
|  - VOID | Return |
|   | SamplePixels |
|  - VOID | Return |
|   | ReadThermistor |
|  - FLOAT | Return |
|   | ReadPixel |
|  - BYTE | Index |
|  - FLOAT | Return |
|   | Initialise |
|  - VOID | Return |
|  - BOOL | Mode |
| 0 = Off, 1 = On | |
|  - VOID | Return |
|   | ClearInterrupt |
|  - VOID | Return |
|   | SetInterruptMode |
|  - BOOL | Mode |
|  - VOID | Return |
|   | SetInterrupt |
|  - BOOL | Mode |
|  - VOID | Return |
|   | SamplePixels |
|  - VOID | Return |
|   | ReadThermistor |
|  - FLOAT | Return |
|   | ReadPixel |
|  - BYTE | Index |
|  - FLOAT | Return |
|   | Initialise |
|  - VOID | Return |
|  - BOOL | Mode |
| 0 = Off, 1 = On | |
|  - VOID | Return |
|   | ClearInterrupt |
|  - VOID | Return |
|   | SetInterruptMode |
|  - BOOL | Mode |
|  - VOID | Return |
|   | SetInterrupt |
|  - BOOL | Mode |
|  - VOID | Return |
|   | SamplePixels |
|  - VOID | Return |
|   | ReadThermistor |
|  - FLOAT | Return |
|   | ReadPixel |
|  - BYTE | Index |
|  - FLOAT | Return |
|   | Initialise |
|  - VOID | Return |
