| Author
Matrix TSL
| Version
2.1
| Category
API Slave Devices
API (BL0032) component
Connects to an BL0032 dsPIC running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / UART / PWM See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_BL0032_API_Comp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_BL0032_API_Comp.fcfx
The App Developer (BL0032 dsPIC E-Block) component allows an BL0032 dsPIC E-block board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the Arduino Uno hardware the board must first be pre-programmed with dedicated firmware.
The firmware hex file and Flowcode source project can be downloaded from here.
BL0032 dsPIC App Developer Firmware
The USB should be connected to the Target port on the E-block board to allow Flowcode to communicate with the Target microcontroller.
The COM port to the E-block hardware is selected via the SCADA_BL0032 component COM port property.
When building the component into a App Developer project remember to expose the COM port property to allow the end user to select the correct port for the hardware.
- fixed statistics showing IO / ADC inputs / PWM
- scrolling log showing all commands and returns
Pin Mapping
Here is a table showing how the slave digital pins are mapped on the device.
| App Developer Slave Digital Pin
0
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
| Device Port Pin
B0
B1
B2
B3
B4
B5
B6
B7
B8
B9
B10
B11
B12
B13
B14
B15
D0
D1
D2
D3
D4
D5
D6
D7
E0
E1
E2
E3
E4
E5
E6
E7
F0
F1
F3
F4
F5
C13
C14
D8
D9
D10
D11
G6
G7
G8
G9
Here is a table showing how the slave analogue pins are mapped on the device.
| App Developer Slave Analogue Pin
0
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| Device Port Pin
B0
B1
B2
B3
B4
B5
B6
B7
B8
B9
B10
B11
B12
B13
B14
B15
E0
E1
E2
E3
E4
E5
E6
E7
Here is a table showing how the slave peripheral pins are mapped on the device.
| App Developer Slave Peripheral Pin
I2C 0 SDA
I2C 0 SCL
I2C 1 SDA
I2C 1 SCL
SPI 0 MOSI
SPI 0 MISO
SPI 0 SCK
SPI 1 MOSI
SPI 1 MISO
SPI 1 SCK
SPI 2 MOSI
SPI 2 MISO
SPI 2 SCK
SPI 3 MOSI
SPI 3 MISO
SPI 3 SCK
UART 0 RX
UART 0 TX
UART 1 RX
UART 1 TX
UART 2 RX
UART 2 TX
UART 3 RX
UART 3 TX
| Device Port Pin
D9
D10
F4
F5
D3
D4
D5
G8
G7
G6
E0
E1
E2
F3
F4
F5
F0
F1
D0
D1
G9
G8
G7
G6
PWM 0
PWM 1
PWM 2
PWM 3
PWM 4
PWM 5
PWM 6
PWM 7
PWM 8
PWM 9
PWM 10
PWM 11
PWM 12
PWM 13
PWM 14
PWM 15
| Device Port Pin
D0
D1
D2
D3
D4
D5
D6
D7
F0
F1
F3
F4
F5
E0
E2
E4
I2CInitialise
| Initialsie the I2C module ready for communications
- BYTE
| Channel Index: Range 0 - I2C Bus Count - 1
- BYTE
Baud
| 0=100KHz, 1=400KHz, 2=1MHz
ADCSampleArray8
| Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples and returns each sample in a single packet
- BYTE
ADCChannel
| Range: 0-5
- BYTE
SampleCount
| Range: 1- 32
- UINT
SampleDelay
| Delay in us between each sample
- BYTE
Samples
| 8-bit samples returned from the function
SPITransferTrans
| Transfer an array of bytes using the SPI bus
- BYTE
| Channel Index: Range 0 - SPI Bus Count - 1
- UINT
Count
| Number of bytes to send and receive
- BYTE
DataOut
| Outgoing data
- BYTE
DataIn
| Incoming data
IOGetInputPin
| Sets the selected digital pin to an input and reads the input state.
- BYTE
Pin
| Range: 0-47 ... Pin 34 unimplemented
- BOOL
UARTBaud
| Control the communications rate of the UART module
- BYTE
| Channel Index: Range 0 - UART Bus Count - 1
- BYTE
Rate
| 0=1200, 1=2400, 2=4800, 3=9600, 4=19200, 5=38400, 6=57600, 7=115200
ADCSample8
- BYTE
ADCChannel
| Range: 0-31 ... Channels 16-23 unimplemented
- BYTE
I2CTransReceive
| Receives an I2C Transaction on the selected I2C channel. Returns the number of bytes received.
- BYTE
- BYTE
Data
| Data variable to receive into
- UINT
Count
| Number of bytes to receive
- UINT
UARTCheckRX
| Check to see if the UART module has received any data
- BYTE
- BYTE
UARTInitialise
| Initialise the UART module ready for communications
- BYTE
RegisterWrite
| Writes to one of the registers on-board the device
- UINT
RegisterAddress
| The address of the register
- UINT
Data
| The data value to assign to the register
ADCSetPrechargeTime
| Specifies the precharge time for the ADC input readings in microseconds. The longer the time the more immune to noise the reading will be.
- BYTE
ChargeTime
| Default 10
RegisterRead
| Read one of the registers on-board the device
- UINT
RegisterAddress
- UINT
I2CRestart
| Put the I2C Module into Restart mode
- BYTE
PWMDisable
| Disable a PWM output
- BYTE
| Range: 0-15
I2CStart
| Put the I2C Module into Start mode
- BYTE
SPITransfer
| Transfer a byte using the SPI bus
- BYTE
- BYTE
DataOut
- BYTE
I2CReceive
| Receive a byte using the I2C bus
- BYTE
- BOOL
Last
| Last byte to receive: Range 0-1
- BYTE
I2CStop
| Put the I2C Module into Stop mode
- BYTE
ADCSetReferenceVoltage
| Specified the reference setting for ADC reads.
- BYTE
RefType
| 0=AREF, 1=VCC, 3=Internal 1.1V
SPIPrescaler
| Modify the speed of the SPI bus
- BYTE
- BYTE
Prescaler
| Range: 0-2
ADCSample12
| Reads the voltage present on an Analog pin as an 12-bit value range 0-4095
- BYTE
ADCChannel
- UINT
PWMSetDuty
| Sets the duty for the PWM output
- BYTE
| Range: 0-15
- BYTE
Duty
I2CTransSend
| Sends an I2C Transaction on the selected I2C channel. Returns the number of bytes sent.
- BYTE
- BYTE
Data
| Data to send
- UINT
Count
| Number of bytes to send out, MS bit 0x8000 signifies no Stop if set
- UINT
I2CTransInit
| Initialises the I2C Transaction mode with the 7-bit device address
- BYTE
- BYTE
DeviceAddress
| 7-bit Device Address
- BYTE
Baud
IOSetOutputPin
| Sets the selected digital pin to an output and assigns the output state.
- BYTE
Pin
- BOOL
State
| Range: 0-1
UARTReceive
| Receives a data byte from the UART. Recommend calling the UARTCheckRx function first to ensure data is available.
- BYTE
- BYTE
ADCSampleAverage10
| Reads the voltage present on an Analog pin as an 10-bit value range 0-1023. Performs the selected number of samples with the selected time in microseconds in between samples
- BYTE
ADCChannel
| Range: 0-5
- BYTE
SampleCount
| Range: 1- 100
- BYTE
SampleDelay
- UINT
SPIInitialise
| Initialsie the SPI module ready for communications
- BYTE
I2CSend
| Transmit a byte using the I2C bus
- BYTE
- BYTE
DataOut
- BOOL
UARTSend
| Send a byte via the UART module
- BYTE
- BYTE
Data
| Data Byte to send. Range: 0-255
PWMSetPrescaler
| Sets the prescaler for the PWM output
- BYTE
| Range: 0-15
- BYTE
Prescaler
- BYTE
Period
| Default 255
PWMEnable
| Enable a PWM output
- BYTE
| Range: 0-15
ADCSampleArray10
| Reads the voltage present on an Analog pin as an 10-bit value range 0-1023 Performs the selected number of samples with the selected time in microseconds in between samples and returns each sample in a single packet
- BYTE
ADCChannel
| Range: 0-5
- BYTE
SampleCount
| Range: 1- 32
- UINT
SampleDelay
- UINT
Samples
| 10-bit samples returned from the function
ADCSampleAverage8
- BYTE
ADCChannel
| Range: 0-5
- BYTE
SampleCount
| Range: 1- 100
- BYTE
SampleDelay
- BYTE
| Initialise the comms to the Arduino board ready for commands to be sent.
Connection
Auto Detect Port
| Allows the component to auto detect the interface board COM port. Requires the latest Flowcode serial comms DLL to function correctly.
COM Port
| Lists all the current available COM port hardware on your PC.
Refresh Ports
API Peripherals
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
SERVO
Console
Console Log
| Create an automatic console log of the commands sent to the Arduino
Log Mode
| Controls how the console data is formatted. Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality Command Log gives a more in depth analysis of the outgoing commands and incoming returns
I2CInitialise
- BYTE
- BYTE
Baud
ADCSampleArray8
- BYTE
ADCChannel
| Range: 0-5
- BYTE
SampleCount
| Range: 1- 32
- UINT
SampleDelay
- BYTE
Samples
SPITransferTrans
- BYTE
- UINT
Count
- BYTE
DataOut
| Outgoing data
- BYTE
DataIn
| Incoming data
IOGetInputPin
- BYTE
Pin
- BOOL
UARTBaud
- BYTE
- BYTE
Rate
ADCSample8
- BYTE
ADCChannel
- BYTE
I2CTransReceive
- BYTE
- BYTE
Data
- UINT
Count
- UINT
UARTCheckRX
- BYTE
- BYTE
UARTInitialise
- BYTE
RegisterWrite
- UINT
RegisterAddress
- UINT
Data
ADCSetPrechargeTime
- BYTE
ChargeTime
| Default 10
RegisterRead
- UINT
RegisterAddress
- UINT
I2CRestart
- BYTE
PWMDisable
- BYTE
| Range: 0-15
I2CStart
- BYTE
SPITransfer
- BYTE
- BYTE
DataOut
- BYTE
I2CReceive
- BYTE
- BOOL
Last
- BYTE
I2CStop
- BYTE
- BYTE
RefType
SPIPrescaler
- BYTE
- BYTE
Prescaler
| Range: 0-2
ADCSample12
- BYTE
ADCChannel
- UINT
PWMSetDuty
- BYTE
| Range: 0-15
- BYTE
Duty
I2CTransSend
- BYTE
- BYTE
Data
| Data to send
- UINT
Count
- UINT
I2CTransInit
- BYTE
- BYTE
DeviceAddress
- BYTE
Baud
IOSetOutputPin
- BYTE
Pin
- BOOL
State
| Range: 0-1
UARTReceive
- BYTE
- BYTE
ADCSampleAverage10
- BYTE
ADCChannel
| Range: 0-5
- BYTE
SampleCount
| Range: 1- 100
- BYTE
SampleDelay
- UINT
SPIInitialise
- BYTE
I2CSend
- BYTE
- BYTE
DataOut
- BOOL
UARTSend
- BYTE
- BYTE
Data
PWMSetPrescaler
- BYTE
| Range: 0-15
- BYTE
Prescaler
- BYTE
Period
| Default 255
PWMEnable
| Enable a PWM output
- BYTE
| Range: 0-15
ADCSampleArray10
- BYTE
ADCChannel
| Range: 0-5
- BYTE
SampleCount
| Range: 1- 32
- UINT
SampleDelay
- UINT
Samples
ADCSampleAverage8
- BYTE
ADCChannel
| Range: 0-5
- BYTE
SampleCount
| Range: 1- 100
- BYTE
SampleDelay
- BYTE
Connection
Auto Detect Port
COM Port
Refresh Ports
API Peripherals
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
SERVO
Console
Console Log
Log Mode
I2CInitialise
- BYTE
- BYTE
Baud
ADCSampleArray8
- BYTE
ADCChannel
| Range: 0-5
- BYTE
SampleCount
| Range: 1- 32
- UINT
SampleDelay
- BYTE
Samples
SPITransferTrans
- BYTE
- UINT
Count
- BYTE
DataOut
| Outgoing data
- BYTE
DataIn
| Incoming data
IOGetInputPin
- BYTE
Pin
- BOOL
UARTBaud
- BYTE
- BYTE
Rate
ADCSample8
- BYTE
ADCChannel
- BYTE
I2CTransReceive
- BYTE
- BYTE
Data
- UINT
Count
- UINT
UARTCheckRX
- BYTE
- BYTE
UARTInitialise
- BYTE
RegisterWrite
- UINT
RegisterAddress
- UINT
Data
ADCSetPrechargeTime
- BYTE
ChargeTime
| Default 10
RegisterRead
- UINT
RegisterAddress
- UINT
I2CRestart
- BYTE
PWMDisable
- BYTE
| Range: 0-15
I2CStart
- BYTE
SPITransfer
- BYTE
- BYTE
DataOut
- BYTE
I2CReceive
- BYTE
- BOOL
Last
- BYTE
I2CStop
- BYTE
- BYTE
RefType
SPIPrescaler
- BYTE
- BYTE
Prescaler
| Range: 0-2
ADCSample12
- BYTE
ADCChannel
- UINT
PWMSetDuty
- BYTE
| Range: 0-15
- BYTE
Duty
I2CTransSend
- BYTE
- BYTE
Data
| Data to send
- UINT
Count
- UINT
I2CTransInit
- BYTE
- BYTE
DeviceAddress
- BYTE
Baud
IOSetOutputPin
- BYTE
Pin
- BOOL
State
| Range: 0-1
UARTReceive
- BYTE
- BYTE
ADCSampleAverage10
- BYTE
ADCChannel
| Range: 0-5
- BYTE
SampleCount
| Range: 1- 100
- BYTE
SampleDelay
- UINT
SPIInitialise
- BYTE
I2CSend
- BYTE
- BYTE
DataOut
- BOOL
UARTSend
- BYTE
- BYTE
Data
PWMSetPrescaler
- BYTE
| Range: 0-15
- BYTE
Prescaler
- BYTE
Period
| Default 255
PWMEnable
| Enable a PWM output
- BYTE
| Range: 0-15
ADCSampleArray10
- BYTE
ADCChannel
| Range: 0-5
- BYTE
SampleCount
| Range: 1- 32
- UINT
SampleDelay
- UINT
Samples
ADCSampleAverage8
- BYTE
ADCChannel
| Range: 0-5
- BYTE
SampleCount
| Range: 1- 100
- BYTE
SampleDelay
- BYTE
Connection
Auto Detect Port
COM Port
Refresh Ports
API Peripherals
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
SERVO
Console
Console Log
Log Mode
I2CInitialise
- BYTE
- BYTE
Baud
ADCSampleArray8
- BYTE
ADCChannel
| Range: 0-5
- BYTE
SampleCount
| Range: 1- 32
- UINT
SampleDelay
- BYTE
Samples
SPITransferTrans
- BYTE
- UINT
Count
- BYTE
DataOut
| Outgoing data
- BYTE
DataIn
| Incoming data
IOGetInputPin
- BYTE
Pin
- BOOL
UARTBaud
- BYTE
- BYTE
Rate
ADCSample8
- BYTE
ADCChannel
- BYTE
I2CTransReceive
- BYTE
- BYTE
Data
- UINT
Count
- UINT
UARTCheckRX
- BYTE
- BYTE
UARTInitialise
- BYTE
RegisterWrite
- UINT
RegisterAddress
- UINT
Data
ADCSetPrechargeTime
- BYTE
ChargeTime
| Default 10
RegisterRead
- UINT
RegisterAddress
- UINT
I2CRestart
- BYTE
PWMDisable
- BYTE
| Range: 0-15
I2CStart
- BYTE
SPITransfer
- BYTE
- BYTE
DataOut
- BYTE
I2CReceive
- BYTE
- BOOL
Last
- BYTE
I2CStop
- BYTE
- BYTE
RefType
SPIPrescaler
- BYTE
- BYTE
Prescaler
| Range: 0-2
ADCSample12
- BYTE
ADCChannel
- UINT
PWMSetDuty
- BYTE
| Range: 0-15
- BYTE
Duty
I2CTransSend
- BYTE
- BYTE
Data
| Data to send
- UINT
Count
- UINT
I2CTransInit
- BYTE
- BYTE
DeviceAddress
- BYTE
Baud
IOSetOutputPin
- BYTE
Pin
- BOOL
State
| Range: 0-1
UARTReceive
- BYTE
- BYTE
ADCSampleAverage10
- BYTE
ADCChannel
| Range: 0-5
- BYTE
SampleCount
| Range: 1- 100
- BYTE
SampleDelay
- UINT
SPIInitialise
- BYTE
I2CSend
- BYTE
- BYTE
DataOut
- BOOL
UARTSend
- BYTE
- BYTE
Data
PWMSetPrescaler
- BYTE
| Range: 0-15
- BYTE
Prescaler
- BYTE
Period
| Default 255
PWMEnable
| Enable a PWM output
- BYTE
| Range: 0-15
ADCSampleArray10
- BYTE
ADCChannel
| Range: 0-5
- BYTE
SampleCount
| Range: 1- 32
- UINT
SampleDelay
- UINT
Samples
ADCSampleAverage8
- BYTE
ADCChannel
| Range: 0-5
- BYTE
SampleCount
| Range: 1- 100
- BYTE
SampleDelay
- BYTE
Connection
Auto Detect Port
COM Port
Refresh Ports
API Peripherals
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
SERVO
Console
Console Log
Log Mode
