Component: Output DAC (DSP Outputs)
Revision as of 15:20, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Outputs
Output DAC component
Allows the values from a buffer to be passed directly to an internal DAC output.
Please click here to download the component source project: FC_Comp_Source_DSP_DAC.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_DAC.fcfx
OutputDACArray
Outputs an array of values from the input buffer appropriatley scaled to suit the DAC.
- UINT Delay
Delay in microseconds between outputting each sample.
ControlDAC
Enable or disable the DAC output, Disabled by default.
- BOOL State
OutputDAC
Outputs a single value from the input buffer appropriatley scaled to suit the DAC.
Connect To
DAC Channel number
DAC Output Pin
DAC Output Pin
DAC
Auto Adjust Scale
Yes: Automatically convert samples to match the full bit depth of the DAC. No: Leave the samples at the native bit depth.
Vref Option
Vref Voltage
Control Bits
Resolution
Voltage Resolution
Bit Depth
Max number of bits for each DAC sample.
OutputDACArray
- UINT Delay
ControlDAC
- BOOL State
OutputDAC
Connect To
DAC Channel number
DAC Output Pin
DAC Output Pin
DAC
Auto Adjust Scale
Vref Option
Vref Voltage
Control Bits
Resolution
Voltage Resolution
Bit Depth
OutputDACArray
- UINT Delay
ControlDAC
- BOOL State
OutputDAC
Connect To
DAC Channel number
DAC Output Pin
DAC Output Pin
DAC
Auto Adjust Scale
Vref Option
Vref Voltage
Control Bits
Resolution
Voltage Resolution
Bit Depth
