Component: Switch (Push, Dashboard) ()
Author | Matrix Ltd |
Version | 1.1 |
Category |
Switch (Push, Dashboard) component
Simple momentary push-button using the Matrix dashboard theme.
Please click here to download the component source project: FC_Comp_Source_Dashboard_Button.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Dashboard_Button.fcfx
Switch
(5V / 11K) * 10K = 4.54545V
