| Author
Matrix TSL
| Version
1.4
| Category
Segment
Starburst Display component
Starburst 14 or 16 segment display modelled after a standard 14mm high unit. LED colour can be changed in properties.
Please click here to download the component source project: FC_Comp_Source_LED_Starburst_Single.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Starburst_Single.fcfx
Example program showing how to use the starburst display component to display alphanumeric ASCII characters.
Starburst Test
Example program showing how to multiplex between several starburst displays. Takes an ADC reading and displays the reading in decimal using 4 starburst display components.
Starburst Multi
Example program showing how to multiplex between several starburst displays. Takes an ADC reading and displays the reading in hexadecimal using 4 starburst display components.
Starburst Multi Hex
ClearSegments
| This funtion clears all the individual segments including the decimal point segment. In simulation this sets the colours to the default BGColor component variable.
ShowSegments
| Creates the supplied digit on the 7 segment display. Macro takes the digit to display and a boolean representing whether to display the decimal point segment or not.
- BYTE
Segments0
| Segment bits 0=Off 1=On : F/E/D2/D/C/B/A2/A
- BYTE
Segments1
| Segment bits 0=Off 1=On : M/L/K/J/I/H/G2/G1
- BYTE
DecimalPoint
| Segment bits 0=Off 1=On : DecimalPoint
ShowCharacter
| Allows certain pre-programmed characters to be displayed. 0-9, A-Z, $, [, ], +, -, \, /, *, _, {, }, .
- BYTE
Character
| 0-9 or A-Z
- BYTE
DecimalPoint
| 0=Off, 1=On
Display Segments
| Controls the starburst display type and number of segments available.
Display Type
| Set this property to match your hardware device. Common Anode: Common Pin High, Segment Pin Low = LED On Common Cathode: Common Pin Low, Segment Pin High = LED On
Common Mode
| Controls if the display will be multiplexed or always on. Multplexed uses the common pin to switch a individual display on or off allowing for multiple displays. Always on removes the common pin assuming you are only using a single starburst display.
Show Seg Labels
| Show the identifier lables of the segments overlayed over the component.
Pin A1
| Pin connected to the 'A1' segment of the display.
Pin A2
| Pin connected to the 'A2' segment of the display.
Pin B
| Pin connected to the 'B' segment of the display.
Pin C
| Pin connected to the 'C' segment of the display.
Pin D1
| Pin connected to the 'D1' segment of the display.
Pin D2
| Pin connected to the 'D2' segment of the display.
Pin E
| Pin connected to the 'E' segment of the display.
Pin F
| Pin connected to the 'F' segment of the display.
Pin G1
| Pin connected to the 'G1' segment of the display.
Pin G2
| Pin connected to the 'G2' segment of the display.
Pin H
| Pin connected to the 'H' segment of the display.
Pin I
| Pin connected to the 'I' segment of the display.
Pin J
| Pin connected to the 'J' segment of the display.
Pin K
| Pin connected to the 'K' segment of the display.
Pin L
| Pin connected to the 'L' segment of the display.
Pin M
| Pin connected to the 'M' segment of the display.
Pin DP
| Pin connected to the decimal point segment of the display.
Common
| Pin connection to the 'common' pin of the display - to allow enable/disable of the whole display.
Colors
LED Color
| Color when an LED is turned on. When turned off, will use a much darker shade of the same hue.
Bezel Color
| Color of the plastic package housing the LEDs
Label Color
| Color of the optional segment name labels.
ClearSegments
ShowSegments
- BYTE
Segments0
- BYTE
Segments1
- BYTE
DecimalPoint
ShowCharacter
- BYTE
Character
| 0-9 or A-Z
- BYTE
DecimalPoint
| 0=Off, 1=On
Display Segments
Display Type
Common Mode
Show Seg Labels
Pin A1
Pin A2
Pin B
Pin C
Pin D1
Pin D2
Pin E
Pin F
Pin G1
Pin G2
Pin H
Pin I
Pin J
Pin K
Pin L
Pin M
Pin DP
Common
Colors
LED Color
Bezel Color
Label Color
ClearSegments
ShowSegments
- BYTE
Segments0
- BYTE
Segments1
- BYTE
DecimalPoint
ShowCharacter
- BYTE
Character
| 0-9 or A-Z
- BYTE
DecimalPoint
| 0=Off, 1=On
Display Segments
Display Type
Common Mode
Show Seg Labels
Pin A1
Pin A2
Pin B
Pin C
Pin D1
Pin D2
Pin E
Pin F
Pin G1
Pin G2
Pin H
Pin I
Pin J
Pin K
Pin L
Pin M
Pin DP
Common
Colors
LED Color
Bezel Color
Label Color
