| Author
Matrix TSL
| Version
1.1
| Category
MIAC Module
MIAC NXT / ECU component
Component to drive the MIAC NXT / MIAC ECU range of hardware.
Please click here to download the component source project: FC_Comp_Source_MIAC_NXT_Component_Source.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MIAC_NXT_Component_Source.fcfx
TransistorOutputState
| Allows one of the high speed transistor outputs ( A - F ) to be pulled to GND, Pulled to +V or disabled.
- BYTE
| Range: 1 - 6 where 1=A / 2=B / 3=C / 4=D / 5=E / 6=F
- BYTE
State
| 0 = Pull to Ground / 1 = Pull to +V / 2 = DisableOutput
DisplayPrintFormattedNumber
| Will allow you to print a number up to 32-bits with signed or unsigned formatting. Signed = -2147483648 to 2147483647 Unsigned = 0 to 4294967295
- ULONG
Number
| Enter the number or variable to print to the display
- BOOL
Format
| 0 = Signed, 1 = Unsigned
DisplayPrintFloat
| Prints a formatted floating point number to the display
- FLOAT
Number
- BYTE
DecimalPoints
| Number of decimal points to display
DisplayGetCursorPosition
| Gets the current pixel position of the cursor within the coordinate space
- BYTE
Axis
| 0=X, 1=Y
- UINT
ReadTransistorOutputCurrent
| Reads the current for one of the transistor outputs ( A - F ) Returns the current as a floating point number in amps
- BYTE
| Range: 1 - 6 - 1=A / 2=B / 3=C / 4=D / 5=E / 6=F
- FLOAT
RelayOutputState
| Allows one of the relay outputs ( Q1 - Q2 ) to be switched on or off.
- BYTE
| Range: 1 - 2 Where 1=Q1 / 2=Q2
- BOOL
State
| 0 = Relay Open Circuit / 1 = Relay Closed Circuit
ReadUSBConnected
| Checks to see if there is an active USB cable connected to the MIAC. Returns 1 if there is a USB cable present, otherwise returns 0.
- BOOL
InputAnalogByte
| Reads one of the input channels ( IN1 - IN8 ) as an analogue value with range 0-255
- BYTE
| Range: 1 - 8
- BYTE
ReadKeypad
| Directly reads the keypad for any current switch inputs. Returns the keypad switch states as a 9-bit value. Bit0 = TopLeft, Bit1 = TopMiddle, Bit2 = TopRight, Bit3 = CenterLeft, etc..
- UINT
ReadEEPROM
| Read a single byte from the EEPROM.
- UINT
Address
- BYTE
DisplayClear
| Clears all text from the display
DisplayPixel
| Sets or clears a pixel at location X, Y.
- UINT
X1
- UINT
Y1
- BOOL
State
| 0=Off / 1=On
WriteEEPROM
| Write a single byte to a location in the EEPROM.
- UINT
Address
- BYTE
Data
DisplayClearLine
| Clears a single line of text from the display
- BYTE
Line
| Line to clear. Range 0 to CharacterHeight - 1
DisplayPrintASCII
| Prints a single ASCII character to the display
- BYTE
Character
| Holds an ASCII value e.g. 'A'
TransistorPWMDuty
| Sets the PWM duty on the selected channel
- BYTE
| Range: 1-4 Where 1=A / 2=B / 3=C / 4=D
- BOOL
EnableOrState
| 1 = Enable / 0 = State
- UINT
Duty
| Range: 0 - 65535
DisplayPrintString
| Prints a string of ASCII characters to the display
- STRING
Text
| Enter the text or variable to print to the display
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
TransistorPWMEnable
| Enables or disables PWM on the selected channel
- BYTE
- BOOL
EnableOrState
| PWM on Enable Pin or State Pin - 1 = Enable / 0 = State
- BOOL
OnOrOff
| 1 = Enabled / 0 = Disabled
DisplayCursor
| Moves the current pixel position of the cursor within the coordinate space
- UINT
X
| Sets the pixel position on the X plane, 0 is the left most pixel
- UINT
Y
| Sets the pixel position on the Y plane, 0 is the top most pixel
InputDigital
| Reads one of the input channels ( IN1 - IN8 ) as a digital value with range 0-1
- BYTE
| Range: 1 - 8
- BOOL
DisplayPrintNumber
| Prints a number to the display as an ASCII string
- INT
Number
InputAnalogInt
| Reads one of the input channels ( IN1 - IN8 ) as an analogue value with range 0-4095
- BYTE
| Range: 1 - 8
- UINT
| Starts up the MIAC IO and display.
Transistor Output PWM Settings
Prescaler Divide
| Allows the user to change the number of program cycles per PWM cycle count. Note that all PWM channels based on the same timer will share the same prescaler.
Period Register
| Allows the user to change the number of counts for the whole PWM period. Note that all PWM channels based on the same timer will share the same period overflow. PIC/AVR Range: 0 - 255 16-bit PIC Range: 0 - 65535
PWM Timer
| Timer associated with PWM to drive the output. Warning - All PWM channels linked to the same timer will share the same period and prescaler settings.
Frequency (Hz)
Display Settings
Foreground Color
Background Color
Font
Character Spacing
Space Width
Pin Connections
CAN (2 x Internal + 1 x External MCP2515)
C1 TX
C1 RX
C2 TX
C2 RX
C3 MOSI
C3 MISO
C3 SCK
C3 CS
C3 INT
C3 RES
LIN
LIN TX
LIN RX
LIN Enable
Bluetooth RN4678
BT TX
BT RX
BT Reset
Wifi ESP12S
Wifi TX
Wifi RX
Wifi Reset
Ethernet W5500
ETH MOSI
ETH MISO
ETH SCK
ETH CS
ETH INT
ETH RES
- BYTE
- BYTE
State
- ULONG
Number
- BOOL
Format
DisplayPrintFloat
- FLOAT
Number
- BYTE
DecimalPoints
- BYTE
Axis
| 0=X, 1=Y
- UINT
- BYTE
- FLOAT
RelayOutputState
- BYTE
- BOOL
State
ReadUSBConnected
- BOOL
InputAnalogByte
- BYTE
| Range: 1 - 8
- BYTE
ReadKeypad
- UINT
ReadEEPROM
- UINT
Address
- BYTE
DisplayClear
DisplayPixel
- UINT
X1
- UINT
Y1
- BOOL
State
| 0=Off / 1=On
WriteEEPROM
- UINT
Address
- BYTE
Data
DisplayClearLine
- BYTE
Line
DisplayPrintASCII
- BYTE
Character
TransistorPWMDuty
- BYTE
- BOOL
EnableOrState
- UINT
Duty
| Range: 0 - 65535
DisplayPrintString
- STRING
Text
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
TransistorPWMEnable
- BYTE
- BOOL
EnableOrState
- BOOL
OnOrOff
DisplayCursor
- UINT
X
- UINT
Y
InputDigital
- BYTE
| Range: 1 - 8
- BOOL
DisplayPrintNumber
- INT
Number
InputAnalogInt
- BYTE
| Range: 1 - 8
- UINT
Prescaler Divide
Period Register
PWM Timer
Frequency (Hz)
Display Settings
Foreground Color
Background Color
Font
Character Spacing
Space Width
Pin Connections
C1 TX
C1 RX
C2 TX
C2 RX
C3 MOSI
C3 MISO
C3 SCK
C3 CS
C3 INT
C3 RES
LIN
LIN TX
LIN RX
LIN Enable
Bluetooth RN4678
BT TX
BT RX
BT Reset
Wifi ESP12S
Wifi TX
Wifi RX
Wifi Reset
Ethernet W5500
ETH MOSI
ETH MISO
ETH SCK
ETH CS
ETH INT
ETH RES
- BYTE
- BYTE
State
- ULONG
Number
- BOOL
Format
DisplayPrintFloat
- FLOAT
Number
- BYTE
DecimalPoints
- BYTE
Axis
| 0=X, 1=Y
- UINT
- BYTE
- FLOAT
RelayOutputState
- BYTE
- BOOL
State
ReadUSBConnected
- BOOL
InputAnalogByte
- BYTE
| Range: 1 - 8
- BYTE
ReadKeypad
- UINT
ReadEEPROM
- UINT
Address
- BYTE
DisplayClear
DisplayPixel
- UINT
X1
- UINT
Y1
- BOOL
State
| 0=Off / 1=On
WriteEEPROM
- UINT
Address
- BYTE
Data
DisplayClearLine
- BYTE
Line
DisplayPrintASCII
- BYTE
Character
TransistorPWMDuty
- BYTE
- BOOL
EnableOrState
- UINT
Duty
| Range: 0 - 65535
DisplayPrintString
- STRING
Text
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
TransistorPWMEnable
- BYTE
- BOOL
EnableOrState
- BOOL
OnOrOff
DisplayCursor
- UINT
X
- UINT
Y
InputDigital
- BYTE
| Range: 1 - 8
- BOOL
DisplayPrintNumber
- INT
Number
InputAnalogInt
- BYTE
| Range: 1 - 8
- UINT
Prescaler Divide
Period Register
PWM Timer
Frequency (Hz)
Display Settings
Foreground Color
Background Color
Font
Character Spacing
Space Width
Pin Connections
C1 TX
C1 RX
C2 TX
C2 RX
C3 MOSI
C3 MISO
C3 SCK
C3 CS
C3 INT
C3 RES
LIN
LIN TX
LIN RX
LIN Enable
Bluetooth RN4678
BT TX
BT RX
BT Reset
Wifi ESP12S
Wifi TX
Wifi RX
Wifi Reset
Ethernet W5500
ETH MOSI
ETH MISO
ETH SCK
ETH CS
ETH INT
ETH RES
