Component: Simulation External Input (Runtime Tools)
Version | 1.1 |
Category | Runtime Tools |
Simulation External Input component
A simulation only component designed to allow a single digital pin to be toggled at a set frequency. Allows things like switch presses or external square waves to be used with the simulation.
Please click here to download the component source project: FC_Comp_Source_Sim_External_Input.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Sim_External_Input.fcfx
Control_Pulse |
Controls if the toggle input is enabled or disabled allowing you to stop and start the waveform. | |
State |
0=Disabled, 1=Enabled | |
Return |
Get_Pulse_Count |
Reads the number of pulses remaining in the current run. The Pulse Count property needs to have an initial value > 0 to switch on the pulse counting mode. | |
Return |
Set_Space |
Overrides the component property setting allowing for a variable frequency input or adjustable Space timings. | |
Delay |
Delay between transitiions in milliseconds. | |
Return |
Set_Frequency |
Allows the frequency to be changed on the fly | |
Frequency |
Return |
Set_Mark |
Overrides the component property setting allowing for a variable frequency input or adjustable Mark timings. | |
Delay |
Return |
Control_Pulse |
State |
Return |
Get_Pulse_Count |
Return |
Set_Space |
Delay |
Return |
Set_Frequency |
Frequency |
Return |
Set_Mark |
Delay |
Return |
Control_Pulse |
State |
Return |
Get_Pulse_Count |
Return |
Set_Space |
Delay |
Return |
Set_Frequency |
Frequency |
Return |
Set_Mark |
Delay |
Return |
