Component: ADC dial ()
| Author | MatrixTSL |
| Version | 1.3 |
| Category |
ADC dial component
An ADC component represented by a dial
Please click here to download the component source project: FC_Comp_Source_adc_dial.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_adc_dial.fcfx
Read a 8-bit Byte
Simple ADC example allowing analogue values to be read on ADC inputs AN0 and AN1 as a byte, these are then displayed on the LCD connected to PortB as a number ranging from 0-255 representing 0V to VCC.
Read a 10-bit or 12-bit sample
Simple ADC example allowing analogue values to be read on ADC inputs AN0 and AN1 as a 10 or 12-bit value depending on the target microcontroller, these are then displayed on the LCD connected to PortB as a number ranging from 0-1023 or 0-4095 representing 0V to VCC.
Reading a sample as a Voltage
Simple ADC example allowing analogue Voltages to be read on ADC inputs AN0 and AN1, these are then displayed on the LCD connected to PortB in Volts from 0.0V-VCC. The VRef Voltage property needs to be correct for the Voltage to be calculated correctly.
Filtering ADC Inputs
Analogue Inputs Window
The Analogue inputs window available from the View menu allows you to see the values for all of the analogue inputs which are active in your program. They can also be manually altered by dragging the mouse along one of the sliders.
Chip Diagram
Active analogue inputs are highlighted in yellow on the chip diagram.
Scope Window
Based on the Scope Traces component property.
Error creating thumbnail: Unable to save thumbnail to destination
Properties |
Connections |
Channel |
Settings |
VRef voltage |
| Used by the GetVoltage or GetString component macros to take an ADC reading and convert it into a Voltage. +VRef voltage x 10mV Default 500 = 5.0V | |
VRef option |
| Defines what is used as the ADC maximum reference. ADC Range = GND to VRef Voltage. VDD - Defines the microcontrollers power supply pin as the max reference, VREF+ Pin - Dedicated pin on the microcontroller to allow for a variable reference voltage. | |
Conversion speed |
| Clock setting to select how fast the ADC peripheral will perform an ADC conversion. The FRC setting is based on a RC time base and so will vary with temperature and pressure. Other settings are generally based on divisions of the master clock. | |
Acquisition cycles |
| Number of micro seconds to wait for the ADC input to charge before starting the analogue sample. | |
Bit Depth |
| Maximum number of digital bits the ADC can sample. 8 bit = ADC range 0 - 255 10 bit = ADC range 0 - 1023 12 bit = ADC range 0 - 4095 | |
Simulation |
Scope Traces |
| Selects if the scope traces are automatically generated or not | |
Properties |
Connections |
Channel |
Settings |
VRef voltage |
VRef option |
Conversion speed |
Bit Depth |
Simulation |
Scope Traces |
Properties |
Connections |
Channel |
Settings |
VRef voltage |
VRef option |
Conversion speed |
Bit Depth |
Simulation |
Scope Traces |
