Component: Reprap Mendel 3D Printer ()
Revision as of 09:54, 27 January 2023 by Wiki bot (talk | contribs)
Category
Reprap Mendel 3D Printer component
A version of the basic 3D printer simulation which has been wrapped with a Reprap Mendel style mesh.
Please click here to download the component source project: FC_Comp_Source_3DPrinter.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_3DPrinter.fcfx
ClearPrevPrint
ControlPrintHead
- BYTE Enable
MoveByXYZ
- INT X
- INT Y
- INT Z
MoveToHome
MoveToXYZ
- INT X
- INT Y
- INT Z
MoveByXYZReal
- FLOAT X
- FLOAT Y
- FLOAT Z
MoveToXYZReal
- FLOAT X
- FLOAT Y
- FLOAT Z
Motor X
Coil 0
Coil 1
Coil 2
Coil 3
Motor Y
Coil 0
Coil 1
Coil 2
Coil 3
Motor Z
Coil 0
Coil 1
Coil 2
Coil 3
Extruder
Coil 0
Coil 1
Coil 2
Coil 3
Show Coils
Bed Width (X)
Bed Height (Y)
Bed Depth (Z)
Print Speed (0 - 100)
Print Type
Print Size
Print Shape
ClearPrevPrint
ControlPrintHead
- BYTE Enable
MoveByXYZ
- INT X
- INT Y
- INT Z
MoveToHome
MoveToXYZ
- INT X
- INT Y
- INT Z
MoveByXYZReal
- FLOAT X
- FLOAT Y
- FLOAT Z
MoveToXYZReal
- FLOAT X
- FLOAT Y
- FLOAT Z
Motor X
Coil 0
Coil 1
Coil 2
Coil 3
Motor Y
Coil 0
Coil 1
Coil 2
Coil 3
Motor Z
Coil 0
Coil 1
Coil 2
Coil 3
Extruder
Coil 0
Coil 1
Coil 2
Coil 3
Show Coils
Bed Width (X)
Bed Height (Y)
Bed Depth (Z)
Print Type
Print Size
Print Shape
ClearPrevPrint
ControlPrintHead
- BYTE Enable
MoveByXYZ
- INT X
- INT Y
- INT Z
MoveToHome
MoveToXYZ
- INT X
- INT Y
- INT Z
MoveByXYZReal
- FLOAT X
- FLOAT Y
- FLOAT Z
MoveToXYZReal
- FLOAT X
- FLOAT Y
- FLOAT Z
Motor X
Coil 0
Coil 1
Coil 2
Coil 3
Motor Y
Coil 0
Coil 1
Coil 2
Coil 3
Motor Z
Coil 0
Coil 1
Coil 2
Coil 3
Extruder
Coil 0
Coil 1
Coil 2
Coil 3
Show Coils
Bed Width (X)
Bed Height (Y)
Bed Depth (Z)
Print Type
Print Size
Print Shape
ClearPrevPrint
ControlPrintHead
- BYTE Enable
MoveByXYZ
- INT X
- INT Y
- INT Z
MoveToHome
MoveToXYZ
- INT X
- INT Y
- INT Z
MoveByXYZReal
- FLOAT X
- FLOAT Y
- FLOAT Z
MoveToXYZReal
- FLOAT X
- FLOAT Y
- FLOAT Z
Motor X
Coil 0
Coil 1
Coil 2
Coil 3
Motor Y
Coil 0
Coil 1
Coil 2
Coil 3
Motor Z
Coil 0
Coil 1
Coil 2
Coil 3
Extruder
Coil 0
Coil 1
Coil 2
Coil 3
Show Coils
Bed Width (X)
Bed Height (Y)
Bed Depth (Z)
Print Type
Print Size
Print Shape
ClearPrevPrint
ControlPrintHead
- BYTE Enable
MoveByXYZ
- INT X
- INT Y
- INT Z
MoveToHome
MoveToXYZ
- INT X
- INT Y
- INT Z
MoveByXYZReal
- FLOAT X
- FLOAT Y
- FLOAT Z
MoveToXYZReal
- FLOAT X
- FLOAT Y
- FLOAT Z
Motor X
Coil 0
Coil 1
Coil 2
Coil 3
Motor Y
Coil 0
Coil 1
Coil 2
Coil 3
Motor Z
Coil 0
Coil 1
Coil 2
Coil 3
Extruder
Coil 0
Coil 1
Coil 2
Coil 3
Show Coils
Bed Width (X)
Bed Height (Y)
Bed Depth (Z)
Print Type
Print Size
Print Shape
