| Author
Matrix Ltd.
| Version
2.0
| Category
Movement Orientation
Accelerometer 3-Axis (MMA8452Q) component
MMA8452Q Accelerometer sensor with I2C. Useful for approximating Pitch and Roll or for detecting acceleration.
Please click here to download the component source project: FC_Comp_Source_Accelerometer_MMA8452Q.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Accelerometer_MMA8452Q.fcfx
Read_Register
| Reads a value from a register on the accelerometer.
- BYTE
Reg
| Register address to read from
- BYTE
SimReset1G
| Resets the simulation to 0.0 on X and Y and 1.0 on Z as if the accelerometer was sitting completely horizontal.
Write_Register
| Writes a data value to a specific register on the accelerometer
- BYTE
Reg
| Register Address to Write to
- BYTE
Data
| Value to write to the register
CollectXYZData
| Collect the data from the local accelerometer buffers. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
- BYTE
Axis
- INT
UpdateXYZData
| Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
- BYTE
Read_N_Registers
| Reads a set of data values from sequential registers on the accelerometer
- BYTE
Start_Reg
| First address to read data from
- BYTE
Num_Regs
| Number of registers to read
- BYTE
data
| Data variable to populate with the register values
SimSetXYZ
| Allows the XYZ slider values to be set via the simulation
- INT
X
- INT
Y
- INT
Z
| Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
- BYTE
Bit Depth
| The number of binary bits used to store the sensor's X,Y,Z readings.
Scale
| The accelerometer readings are scaled based on the maximum amount of G force the sensor can represent. 6G = Bigger gravitational force 2G = Higher resolution
Data Rate
Int Option
| Sets if we use the interrupt pin to check if new data is available
Device Address
I2C Connections
| Channel selection
Baud Select
| Baud rate option selector
| Baud rate to be used
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Simulate Comms
| Yes: Accelerometer data will come from the simulation component sliders. No: Accelerometer data will come from the CAL component - I2C or SPI - API etc
Read_Register
- BYTE
Reg
- BYTE
SimReset1G
Write_Register
- BYTE
Reg
- BYTE
Data
CollectXYZData
- BYTE
Axis
- INT
UpdateXYZData
- BYTE
Read_N_Registers
- BYTE
Start_Reg
- BYTE
Num_Regs
- BYTE
data
SimSetXYZ
- INT
X
- INT
Y
- INT
Z
- BYTE
Bit Depth
Scale
Data Rate
Int Option
Device Address
I2C Connections
| Channel selection
Baud Select
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Simulate Comms
Read_Register
- BYTE
Reg
- BYTE
SimReset1G
Write_Register
- BYTE
Reg
- BYTE
Data
CollectXYZData
- BYTE
Axis
- INT
UpdateXYZData
- BYTE
Read_N_Registers
- BYTE
Start_Reg
- BYTE
Num_Regs
- BYTE
data
SimSetXYZ
- INT
X
- INT
Y
- INT
Z
- BYTE
Bit Depth
Scale
Data Rate
Int Option
Device Address
I2C Connections
| Channel selection
Baud Select
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Simulate Comms
Read_Register
- BYTE
Reg
- BYTE
SimReset1G
Write_Register
- BYTE
Reg
- BYTE
Data
CollectXYZData
- BYTE
Axis
- INT
UpdateXYZData
- BYTE
Read_N_Registers
- BYTE
Start_Reg
- BYTE
Num_Regs
- BYTE
data
SimSetXYZ
- INT
X
- INT
Y
- INT
Z
- BYTE
Bit Depth
Scale
Data Rate
Int Option
Device Address
I2C Connections
| Channel selection
Baud Select
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Simulate Comms
Read_Register
- BYTE
Reg
- BYTE
SimReset1G
Write_Register
- BYTE
Reg
- BYTE
Data
CollectXYZData
- BYTE
Axis
- INT
UpdateXYZData
- BYTE
Read_N_Registers
- BYTE
Start_Reg
- BYTE
Num_Regs
- BYTE
data
SimSetXYZ
- INT
X
- INT
Y
- INT
Z
- BYTE
Bit Depth
Scale
Data Rate
Int Option
Device Address
I2C Connections
| Channel selection
Baud Select
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Simulate Comms
