Component: Ternary Chart (Charts)
Revision as of 09:55, 27 January 2023 by Wiki bot (talk | contribs)
Author Steve Tandy
Version 2.0
Category Charts
Ternary Chart component
A 3-axis ternary chart component.
Please click here to download the component source project: FC_Comp_Source_ChartTernary.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ChartTernary.fcfx
Clear
Resets the XY chart and removes all data points.
AddPoint
Add a data bubble to the selected data series.
- FLOAT X
The X coordinate of the data point
- FLOAT Y
The Y coordinate of the data point
- FLOAT Z
The value of the data point bubble
- BYTE index
Which series to add to (1-8)
Style
Title
Fill Gradient
Transparency
Axes
X-axis
Y-axis
Z-axis
Show Grid
Data Labels
Show
Angle
Legend
Position
Draw Border
Show Datapoints
Select Series
Series1
Series Name
Visible
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Clear
AddPoint
- FLOAT X
- FLOAT Y
- FLOAT Z
- BYTE index
Style
Title
Fill Gradient
Transparency
Axes
X-axis
Y-axis
Z-axis
Show Grid
Data Labels
Show
Angle
Legend
Position
Draw Border
Show Datapoints
Select Series
Series1
Series Name
Visible
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Clear
AddPoint
- FLOAT X
- FLOAT Y
- FLOAT Z
- BYTE index
Style
Title
Fill Gradient
Transparency
Axes
X-axis
Y-axis
Z-axis
Show Grid
Data Labels
Show
Angle
Legend
Position
Draw Border
Show Datapoints
Select Series
Series1
Series Name
Visible
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Clear
AddPoint
- FLOAT X
- FLOAT Y
- FLOAT Z
- BYTE index
Style
Title
Fill Gradient
Transparency
Axes
X-axis
Y-axis
Z-axis
Show Grid
Data Labels
Show
Angle
Legend
Position
Draw Border
Show Datapoints
Select Series
Series1
Series Name
Visible
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Clear
AddPoint
- FLOAT X
- FLOAT Y
- FLOAT Z
- BYTE index
Style
Title
Fill Gradient
Transparency
Axes
X-axis
Y-axis
Z-axis
Show Grid
Data Labels
Show
Angle
Legend
Position
Draw Border
Show Datapoints
Select Series
Series1
Series Name
Visible
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
