| Author
Matrix TSL
| Version
1.0
| Category
Analog Output
DAC (MCP49x1) component
Component to drive a digital to analogue converter (DAC) IC from Microchip via an SPI interface. Compatible with MCP4901 (8-Bit), MCP4911 (10-Bit) and MCP4921 (12-Bit) devices.
Please click here to download the component source project: FC_Comp_Source_DAC_MCP49x1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DAC_MCP49x1.fcfx
SetOutput
| Sets the output voltage of the DAC 8-Bit: Range 0-255 10-Bit: Range 0-1023 12-Bit: Range 0-4095
- UINT
DAC_Value
| The value to output to the DAC
ControlPins
| Allows Shutdown (SHDN) and Latch (LDAC) pins to be controlled directly if enabled.
- BOOL
Shutdown
| 0 = Shutdown Device, 1 = Device Active
- BOOL
Latch
| 0 = Data output driven from DAC register, 1 = Data output locked
Disable
| Disables the DAC output.
Enable
| Enables the DAC Output.
- BYTE
| 0=DAC Channel 0 , 1=DAC Channel 1
| Configures the SPI peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated.
DAC IC
| Selects which DAC IC is connected and therefore the bit depth available.
Gain Option
| Selects the maximum reference value for the DAC
Vref Pin Voltage
| The reference voltage applied to the VREF pin.
Vref Voltage
| Reference Voltage, Used to calculate the Voltage resolution.
Steps
| Number of discrete output states available from the DAC.
Control Bits
| Number of digital control bits
Resolution
| Maximum output resolution based on number of control bits.
Voltage Resolution
| Specifies the Resolution per digital bit in terms of Voltage.
SPI Connections
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MOSI Remap Pin
| Select which the target pin to assign the MOSI hardware pin functionality.
MISO
MISO Remap Pin
| Select which the target pin to assign the MISO hardware pin functionality.
CLK
CLK Remap Pin
| Select which the target pin to assign the CLK hardware pin functionality.
CS / SS
| Chip Select / Slave Select Pin Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
Use SHDN Pin
| Allows the SHDN pin to be driven from an output pin on the microcontroller. If not used then tie the SHDN pin to VCC to allow the DAC to function.
Use LDAC Pin
| Allows the LDAC pin to be driven from an output pin on the microcontroller. If not used then tie the LDAC pin to GND to allow the DAC to function.
Simulate Comms
SetOutput
- UINT
DAC_Value
ControlPins
- BOOL
Shutdown
- BOOL
Latch
Disable
Enable
- BYTE
DAC IC
Gain Option
Vref Pin Voltage
Vref Voltage
Steps
Control Bits
Resolution
Voltage Resolution
SPI Connections
Prescale
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
CLK Remap Pin
CS / SS
Use SHDN Pin
Use LDAC Pin
Simulate Comms
SetOutput
- UINT
DAC_Value
ControlPins
- BOOL
Shutdown
- BOOL
Latch
Disable
Enable
- BYTE
DAC IC
Gain Option
Vref Pin Voltage
Vref Voltage
Steps
Control Bits
Resolution
Voltage Resolution
SPI Connections
Prescale
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
CLK Remap Pin
CS / SS
Use SHDN Pin
Use LDAC Pin
Simulate Comms
SetOutput
- UINT
DAC_Value
ControlPins
- BOOL
Shutdown
- BOOL
Latch
Disable
Enable
- BYTE
DAC IC
Gain Option
Vref Pin Voltage
Vref Voltage
Steps
Control Bits
Resolution
Voltage Resolution
SPI Connections
Prescale
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
CLK Remap Pin
CS / SS
Use SHDN Pin
Use LDAC Pin
Simulate Comms
