Component: Output Digital (DSP Outputs)
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 1.2 |
| Category | DSP Outputs |
Output Digital component
Allows the values from a buffer to be read. Either a value at a time or as an array.
Please click here to download the component source project: FC_Comp_Source_DSP_Output.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Output.fcfx
| GetIntArray | |
| Returns an array of integer values from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
| Data | |
| Count | |
| GetLongArray | |
| Returns an array of long values from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
| Data | |
| Count | |
| GetFloatArray | |
| Returns an array of float values from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
| Data | |
| Count | |
| GetFloat | |
| Returns a float value from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
| GetLong | |
| Returns a long value from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
| GetInt | |
| Returns an integer value from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
| GetByteArray | |
| Returns an array of byte values from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
| Data | |
| Count | |
| GetByte | |
| Returns a byte value from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
| GetIntArray | |
| Data | |
| Count | |
| GetLongArray | |
| Data | |
| Count | |
| GetFloatArray | |
| Data | |
| Count | |
| GetFloat | |
| GetLong | |
| GetInt | |
| GetByteArray | |
| Data | |
| Count | |
| GetByte | |
| GetIntArray | |
| Data | |
| Count | |
| GetLongArray | |
| Data | |
| Count | |
| GetFloatArray | |
| Data | |
| Count | |
| GetFloat | |
| GetLong | |
| GetInt | |
| GetByteArray | |
| Data | |
| Count | |
| GetByte | |
| GetIntArray | |
| Data | |
| Count | |
| GetLongArray | |
| Data | |
| Count | |
| GetFloatArray | |
| Data | |
| Count | |
| GetFloat | |
| GetLong | |
| GetInt | |
| GetByteArray | |
| Data | |
| Count | |
| GetByte | |
