| Author | Matrix Ltd. |
| Version | 1.3 |
| Category | E-blocks 2 |
Bluetooth component
Low level routines for controlling a Microchip RN4677 Bluetooth Module. Also available in the form of the BL0170 Bluetooth E-block. Uses an interrupt to receive characters from the UART and improve reliability, Must be used with a hardware UART channel.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_Bluetooth_RN4677_BL0170.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Bluetooth_RN4677_BL0170.fcfx
|   | ReceiveByte |
| Receives a single data byte from the Bluetooth module. 0-255 signifies valid data / 256 signifies no data available. |
|  - UINT | Timeout |
| Amount of time to wait in milliseconds 0=Wait forever |
|  - UINT | Return |
|   | SendString |
| Sends a string to the Bluetooth module. |
|  - STRING | Command |
|  - BYTE | SendCR |
|  - VOID | Return |
|   | LeaveCommandMode |
| Leaves command mode allowing data to be passed back and forth, |
|  - VOID | Return |
|   | ConnectToMAC |
| Connects to a specific Bluetooth MAC address. Waits up to 5 seconds for connection to be established. Returns 1 if connection was successful. |
|  - STRING | MACAddress |
|  - BOOL | Return |
|   | SendCommand |
| Sends a command string to the Bluetooth module. Returns: 0 = No Reply / 1 = Command sent ok |
|  - BYTE | SendCR |
|  - BYTE | DiscardReply |
| 0=Do not touch the reply, 1=Wait for reply and remove from buffer |
|  - BYTE | Return |
|   | ReceiveCount |
| Returns the number of bytes currently sat waiting in the receive buffer. |
|  - UINT | Return |
|   | ReadString |
| Copies the incoming data from the data string array to a local string variable. |
|  - BYTE | NumBytes |
| Maximum number of bytes to try and read |
|  - STRING | Return |
|   | SendByte |
| Sends a single data byte out to the Bluetooth module. |
|  - BYTE | Data |
|  - VOID | Return |
|   | EnterCommandMode |
| Enters command mode allowing commands to be sent using the SendCommand macro. Returns: 0 = No Reply / 1 = Command Mode OK |
|  - BOOL | Return |
|   | WaitForStringValue |
| Allows us to wait and check for an incoming value. Returns 1 if the string value is found otherwise returns 0. |
|  - STRING | Value |
| String value to look for |
|  - UINT | Timeout |
| Length of time to wait in milliseconds |
|  - BOOL | Return |
|   | GetMACAddress |
| Gets the local Bluetooth device MAC address. |
|  - STRING | Return |
|   | Initialise |
| Sets up the Bluetooth module including:   - Enabling the UART  - Configuring the module (Name / Key / etc) Returns 1 for OK and 0 for no reply. |
|  - BYTE | Return |
|   | Properties |
|   | Bluetooth Settings |
|   | Device Name |
| Sets the friendly name of the Bluetooth device. |
|   | Pair Key |
|   | Discoverable |
| Is the Bluetooth module discoverable by default? |
|   | Reply Timeout |
| Specifies the amount of time to wait for incoming data before timing out in milliseconds. Default 2000 = 2 seconds. |
|   | RX Buffer Size |
| Amount of RAM memory to dedicate to receiving responses and incoming data from the BT module. Default 40 |
|   | Connections |
|   | Channel |
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller. |
|   | Baud Options |
| Baud rate option selector |
|   | Baud Rate |
|   | TX |
| Pin to be used for Transmit data |
|   | TX Remap Pin |
| Allows the hardware transmit pin to be configured from a list of available pins based on your target device, |
|   | RX |
| Pin to be used for Receive data |
|   | RX Remap Pin |
| Allows the hardware receive pin to be configured from a list of available pins based on your target device, |
|   | Simulation |
|   | Simulate Comms |
|   | Simulation |
|   | Scope Traces |
| Selects if the scope traces are automatically added to the data recorder window or not.     Simulation - draws an approximation of the UART data onto the scope trace.     ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD. |
|   | Console Data |
| Selects if the console data is automatically generated or not |
|   | Console Columns |
| Number of characters that can be displayed on a single line of the console. |
|   | Data Source |
| Simulation data source used to allow the component to connect to various remote devices     Nothing - Simulation data is ignored     COM port - Routes the communication data to and from a physical or virtual COM port      Injector - Routes the communication data via a data injector component on the Panel. |
|   | ReceiveByte |
|  - UINT | Timeout |
|  - UINT | Return |
|   | SendString |
|  - BYTE | SendCR |
|  - VOID | Return |
|   | LeaveCommandMode |
|  - VOID | Return |
|   | ConnectToMAC |
|  - BOOL | Return |
|   | SendCommand |
|  - BYTE | SendCR |
|  - BYTE | Return |
|   | ReceiveCount |
|  - UINT | Return |
|   | ReadString |
|  - BYTE | NumBytes |
|  - STRING | Return |
|   | SendByte |
|  - BYTE | Data |
|  - VOID | Return |
|   | EnterCommandMode |
|  - BOOL | Return |
|  - STRING | Value |
|  - UINT | Timeout |
|  - BOOL | Return |
|   | GetMACAddress |
|  - STRING | Return |
|   | Initialise |
|  - BYTE | Return |
|   | Properties |
|   | Device Name |
|   | Pair Key |
|   | Discoverable |
|   | Reply Timeout |
|   | RX Buffer Size |
|   | Connections |
|   | Channel |
|   | Baud Options |
|   | Baud Rate |
|   | TX |
|   | TX Remap Pin |
|   | RX |
|   | RX Remap Pin |
|   | Simulation |
|   | Simulate Comms |
|   | Simulation |
|   | Scope Traces |
|   | Console Data |
|   | Console Columns |
|   | Data Source |
|   | ReceiveByte |
|  - UINT | Timeout |
|  - UINT | Return |
|   | SendString |
|  - BYTE | SendCR |
|  - VOID | Return |
|   | LeaveCommandMode |
|  - VOID | Return |
|   | ConnectToMAC |
|  - BOOL | Return |
|   | SendCommand |
|  - BYTE | SendCR |
|  - BYTE | Return |
|   | ReceiveCount |
|  - UINT | Return |
|   | ReadString |
|  - BYTE | NumBytes |
|  - STRING | Return |
|   | SendByte |
|  - BYTE | Data |
|  - VOID | Return |
|   | EnterCommandMode |
|  - BOOL | Return |
|  - STRING | Value |
|  - UINT | Timeout |
|  - BOOL | Return |
|   | GetMACAddress |
|  - STRING | Return |
|   | Initialise |
|  - BYTE | Return |
|   | Properties |
|   | Device Name |
|   | Pair Key |
|   | Discoverable |
|   | Reply Timeout |
|   | RX Buffer Size |
|   | Connections |
|   | Channel |
|   | Baud Options |
|   | Baud Rate |
|   | TX |
|   | TX Remap Pin |
|   | RX |
|   | RX Remap Pin |
|   | Simulation |
|   | Simulate Comms |
|   | Simulation |
|   | Scope Traces |
|   | Console Data |
|   | Console Columns |
|   | Data Source |
|   | ReceiveByte |
|  - UINT | Timeout |
|  - UINT | Return |
|   | SendString |
|  - BYTE | SendCR |
|  - VOID | Return |
|   | LeaveCommandMode |
|  - VOID | Return |
|   | ConnectToMAC |
|  - BOOL | Return |
|   | SendCommand |
|  - BYTE | SendCR |
|  - BYTE | Return |
|   | ReceiveCount |
|  - UINT | Return |
|   | ReadString |
|  - BYTE | NumBytes |
|  - STRING | Return |
|   | SendByte |
|  - BYTE | Data |
|  - VOID | Return |
|   | EnterCommandMode |
|  - BOOL | Return |
|  - STRING | Value |
|  - UINT | Timeout |
|  - BOOL | Return |
|   | GetMACAddress |
|  - STRING | Return |
|   | Initialise |
|  - BYTE | Return |
|   | Properties |
|   | Device Name |
|   | Pair Key |
|   | Discoverable |
|   | Reply Timeout |
|   | RX Buffer Size |
|   | Connections |
|   | Channel |
|   | Baud Options |
|   | Baud Rate |
|   | TX |
|   | TX Remap Pin |
|   | RX |
|   | RX Remap Pin |
|   | Simulation |
|   | Simulate Comms |
|   | Simulation |
|   | Scope Traces |
|   | Console Data |
|   | Console Columns |
|   | Data Source |
