Component: Joystick 2D (Controls)
Revision as of 09:57, 27 January 2023 by Wiki bot (talk | contribs)
Category Controls
Joystick 2D component
A simple joystick component allowing for easy mouse or touchscreen based analogue control.
Please click here to download the component source project: FC_Comp_Source_Joystick_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Joystick_2dgi.fcfx
ReadAxisAsFloat
Reads a single axis of the joystick and returns as a floating point value.
- BYTE Axis
Range 0-1 Where 0=X, 1=Y
- FLOAT Return
SimMoveThumbStick
- FLOAT X
- FLOAT Y
- HANDLE Component
ReadAxisAsInt
Reads a single axis of the joystick and returns as a signed integer value.
- BYTE Axis
- INT Return
Joystick Type
Defines the directions the joystick can travel.
Return To Center
Decides if the joystick automatically returns to the center position when released. Yes: The joystick will return to the center when released. No: The joystick will remain in the current position when released.
Limits
Y Min
Y Max
Theme
Box Colour
Shaft Colour
Knob Colour
Style
Style
Outline line style
ReadAxisAsFloat
- BYTE Axis
- FLOAT Return
SimMoveThumbStick
- FLOAT X
- FLOAT Y
- HANDLE Component
ReadAxisAsInt
- BYTE Axis
- INT Return
Joystick Type
Return To Center
Limits
Y Min
Y Max
Theme
Box Colour
Shaft Colour
Knob Colour
Style
Style
Outline line style
ReadAxisAsFloat
- BYTE Axis
- FLOAT Return
SimMoveThumbStick
- FLOAT X
- FLOAT Y
- HANDLE Component
ReadAxisAsInt
- BYTE Axis
- INT Return
Joystick Type
Return To Center
Limits
Y Min
Y Max
Theme
Box Colour
Shaft Colour
Knob Colour
Style
Style
Outline line style
ReadAxisAsFloat
- BYTE Axis
- FLOAT Return
SimMoveThumbStick
- FLOAT X
- FLOAT Y
- HANDLE Component
ReadAxisAsInt
- BYTE Axis
- INT Return
Joystick Type
Return To Center
Limits
Y Min
Y Max
Theme
Box Colour
Shaft Colour
Knob Colour
Style
Style
Outline line style
