Component: TCP/IP (Raspberry Pi) (Comms: Networking)
| Author | Matrix Ltd. |
| Version | 1.9 |
| Category | Comms: Networking |
TCP/IP (Raspberry Pi) component
TCP/IP sockets component for use with Raspberry Pi. Raspberry Pi Only
Please click here to download the component source project: FC_Comp_Source_TCPIP_RPI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TCPIP_RPI.fcfx
| Receive | |
| Receive data into the data buffer. Returns the number of bytes received | |
| Data | |
| Data byte buffer to receive the data | |
| Count | |
| Maximum number of bytes to read | |
| Send | |
| Send data | |
| Data | |
| Data byte buffer to send | |
| Count | |
| Number of bytes to send | |
| Listen | |
| Bind the socket to a port on the local host and set to listen mode. First open a socket on the local device using the Socket function and check that it is successful. | |
| Port | |
| SocketClose | |
| Close the socket | |
| AcceptOpen | |
| AcceptClose | |
| Close the accept socket | |
| Initialises the TCP/IP component | |
| Properties | |
| Label | |
| Receive | |
| Data | |
| Count | |
| Send | |
| Send data | |
| Data | |
| Count | |
| Listen | |
| Port | |
| SocketClose | |
| AcceptOpen | |
| AcceptClose | |
| Properties | |
| Label | |
| Receive | |
| Data | |
| Count | |
| Send | |
| Send data | |
| Data | |
| Count | |
| Listen | |
| Port | |
| SocketClose | |
| AcceptOpen | |
| AcceptClose | |
| Properties | |
| Label | |
| Receive | |
| Data | |
| Count | |
| Send | |
| Send data | |
| Data | |
| Count | |
| Listen | |
| Port | |
| SocketClose | |
| AcceptOpen | |
| AcceptClose | |
| Properties | |
| Label | |
