| Author
Matrix Ltd
| Version
1.2
| Category
Audio Output
Speech (Phoneme) component
Speech component allowing Phoneme based speech for use on an embedded platform. The simulation also has an advanced speech engine allowing realistic text to speech in multiple languages using the RealSpeak voice engine.
Please click here to download the component source project: FC_Comp_Source_speech.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_speech.fcfx
Example of Phoneme Speech (download and simulation)
Speech
The Phoneme based speech can be output on Microcontroller hardware using a number of methods.
PWM - Outputs using a single PWM pin, a simple external RC low pass filter can be used to remove the high frequency PWM to create an audio signal.
Parallel - Outputs using a 8-bit port, a simple 8-bit R2R DAC circuit can be used to combine the bits into an audio signal.
Other - A third option is to use the ReadByteFromPhoneme macro to pull out the phoneme values a byte at a time which can be used to pass on to an external DAC etc.
Another example of Phoneme Speech, taking a reading from an analogue channel and speaking the Voltage. (download and simulation)
Talking Volt Meter
Example of Real Speak Speech (simulation only)
Speech2
Adding additional language packs to the Real Speak engine.
Real Speak Voice Downloads
ReadPhonemeLength
| Function to return the number of bytes used in a single phoneme array.
- STRING
Phoneme
| Specifies a single Phoneme
- UINT
EnableOutput
| Sets up the output to allow the speech data to be streamed out.
DisableOutput
| Disables the output to prevent any buzzing etc while not speaking.
ReadByteFromPhoneme
| Reads a single byte value from the specified phoneme data array. This function will not simulate correctly as it requires C style pointers.
- STRING
Phoneme
- UINT
Idx
| Specifies the position within the Phoneme
- BYTE
OutputPhoneme
| Streams a single Phoneme or string of comma seperated Phonemes. OutputPhoneme("OY") OutputPhoneme("OY,AY,OY")
- STRING
DataString
Phoneme Settings
Phoneme Selection
| Selects which phonemes are included in the embedded firmware
Phoneme Data Set
| Specifies if the phonemes used are based on the inbuilt phoneme wav files set or a custom file set. To create your own phonemes, copy the wav files from the components directory, then overwrite the phonemes you wish to edit. Phonemes are re-parsed on simulation start and on compile to C.
Pitch (Hz)
| The frequency at which the phoneme data is output in bytes/samples per second.
Phoneme Data Size
| The number of bytes used by the current phoneme selection
ROM Size
| The maximum number of bytes available in the ROM of the selected target device. The ROM has to contain the program as well as the Phoneme data.
Base ROM Address
| The address in ROM to place the phoneme data. It is recomended to always use the suggested address as this will place the phonemes right at the end of ROM and away from the program.
Suggested Address
| The ideal address to allow all the selected phonemes to fit into the end of the ROM memory Thereby allowing the maximum space for the user program.
Output Mode
| Determines how the phoneme data is going to be output.
PWM Pin
| PWM channel selection used to determine which PWM peripheral to stream the Phoneme data to.
PWM Pin
| The actual port pin assigned to the selected PWM channel.
Phoneme Selection
Select All
| Selects all Phonemes
Select None
| Deselects all Phonemes
PA1 (10ms)
| 10ms Pause - Always included
PA2 (30ms)
| 30ms Pause - Always included
PA3 (50ms)
| 50ms Pause - Always included
PA4 (100ms)
| 100ms Pause - Always included
PA5 (200ms)
| 200ms Pause - Always included
AA - hOt
| Phoneme selection
AE - hAt
| Phoneme selection
AO - AUght
| Phoneme selection
AR - alARm
| Phoneme selection
AW - sOUnd
| Phoneme selection
AX - Apple
| Phoneme selection
AY - skY
| Phoneme selection
BB1 - Brown
| Phoneme selection
BB2 - Business
| Phoneme selection
CH - CHurCH
| Phoneme selection
DD1 - enD
| Phoneme selection
DD2 - Down
| Phoneme selection
DH1 - THey
| Phoneme selection
DH2 - baTHe
| Phoneme selection
EH - Extent
| Phoneme selection
EL - angLE
| Phoneme selection
ER1 - intERupt
| Phoneme selection
ER2 - bIRd
| Phoneme selection
EY - grEAt
| Phoneme selection
FF - Food
| Phoneme selection
GG1 - Get
| Phoneme selection
GG2 - Green
| Phoneme selection
GG3 - anGer
| Phoneme selection
HH1 - Help
| Phoneme selection
HH2 - Hope
| Phoneme selection
IH - sIt
| Phoneme selection
IY - trEAt
| Phoneme selection
JH - inJure
| Phoneme selection
KK1 - Clown
| Phoneme selection
KK2 - tasK
| Phoneme selection
KK3 - Crane
| Phoneme selection
LL - Lake
| Phoneme selection
MM - Milk
| Phoneme selection
NG - aNGer
| Phoneme selection
NN1 - thiN
| Phoneme selection
NN2 - Now
| Phoneme selection
OR - stORe
| Phoneme selection
OW - zOne
| Phoneme selection
OY - nOIse
| Phoneme selection
PP - triP
| Phoneme selection
RR1 - WRite
| Phoneme selection
RR2 - gRease
| Phoneme selection
SH - SHip
| Phoneme selection
SS - teSt
| Phoneme selection
TH - THin
| Phoneme selection
TT1 - tesT
| Phoneme selection
TT2 - Test
| Phoneme selection
UH - bOOk
| Phoneme selection
UW1 - cumpUter
| Phoneme selection
UW2 - fOOd
| Phoneme selection
VV - Vest
| Phoneme selection
WH - WHite
| Phoneme selection
WW - Work
| Phoneme selection
XR - haiR
| Phoneme selection
YR - clEAR
| Phoneme selection
YY1 - compUter
| Phoneme selection
YY2 - Yes
| Phoneme selection
ZH - aZure
| Phoneme selection
ZZ - phaSe
| Phoneme selection
ReadPhonemeLength
- STRING
Phoneme
- UINT
EnableOutput
DisableOutput
ReadByteFromPhoneme
- STRING
Phoneme
- UINT
Idx
- BYTE
OutputPhoneme
- STRING
DataString
Phoneme Settings
Phoneme Selection
Phoneme Data Set
Pitch (Hz)
Phoneme Data Size
ROM Size
Base ROM Address
Suggested Address
Output Mode
PWM Pin
PWM Pin
Phoneme Selection
Select All
Select None
PA1 (10ms)
PA2 (30ms)
PA3 (50ms)
PA4 (100ms)
PA5 (200ms)
AA - hOt
| Phoneme selection
AE - hAt
| Phoneme selection
AO - AUght
| Phoneme selection
AR - alARm
| Phoneme selection
AW - sOUnd
| Phoneme selection
AX - Apple
| Phoneme selection
AY - skY
| Phoneme selection
BB1 - Brown
| Phoneme selection
BB2 - Business
| Phoneme selection
CH - CHurCH
| Phoneme selection
DD1 - enD
| Phoneme selection
DD2 - Down
| Phoneme selection
DH1 - THey
| Phoneme selection
DH2 - baTHe
| Phoneme selection
EH - Extent
| Phoneme selection
EL - angLE
| Phoneme selection
ER1 - intERupt
| Phoneme selection
ER2 - bIRd
| Phoneme selection
EY - grEAt
| Phoneme selection
FF - Food
| Phoneme selection
GG1 - Get
| Phoneme selection
GG2 - Green
| Phoneme selection
GG3 - anGer
| Phoneme selection
HH1 - Help
| Phoneme selection
HH2 - Hope
| Phoneme selection
IH - sIt
| Phoneme selection
IY - trEAt
| Phoneme selection
JH - inJure
| Phoneme selection
KK1 - Clown
| Phoneme selection
KK2 - tasK
| Phoneme selection
KK3 - Crane
| Phoneme selection
LL - Lake
| Phoneme selection
MM - Milk
| Phoneme selection
NG - aNGer
| Phoneme selection
NN1 - thiN
| Phoneme selection
NN2 - Now
| Phoneme selection
OR - stORe
| Phoneme selection
OW - zOne
| Phoneme selection
OY - nOIse
| Phoneme selection
PP - triP
| Phoneme selection
RR1 - WRite
| Phoneme selection
RR2 - gRease
| Phoneme selection
SH - SHip
| Phoneme selection
SS - teSt
| Phoneme selection
TH - THin
| Phoneme selection
TT1 - tesT
| Phoneme selection
TT2 - Test
| Phoneme selection
UH - bOOk
| Phoneme selection
UW1 - cumpUter
| Phoneme selection
UW2 - fOOd
| Phoneme selection
VV - Vest
| Phoneme selection
WH - WHite
| Phoneme selection
WW - Work
| Phoneme selection
XR - haiR
| Phoneme selection
YR - clEAR
| Phoneme selection
YY1 - compUter
| Phoneme selection
YY2 - Yes
| Phoneme selection
ZH - aZure
| Phoneme selection
ZZ - phaSe
| Phoneme selection
ReadPhonemeLength
- STRING
Phoneme
- UINT
EnableOutput
DisableOutput
ReadByteFromPhoneme
- STRING
Phoneme
- UINT
Idx
- BYTE
OutputPhoneme
- STRING
DataString
Phoneme Settings
Phoneme Selection
Phoneme Data Set
Pitch (Hz)
Phoneme Data Size
ROM Size
Base ROM Address
Suggested Address
Output Mode
PWM Pin
PWM Pin
Phoneme Selection
Select All
Select None
PA1 (10ms)
PA2 (30ms)
PA3 (50ms)
PA4 (100ms)
PA5 (200ms)
AA - hOt
| Phoneme selection
AE - hAt
| Phoneme selection
AO - AUght
| Phoneme selection
AR - alARm
| Phoneme selection
AW - sOUnd
| Phoneme selection
AX - Apple
| Phoneme selection
AY - skY
| Phoneme selection
BB1 - Brown
| Phoneme selection
BB2 - Business
| Phoneme selection
CH - CHurCH
| Phoneme selection
DD1 - enD
| Phoneme selection
DD2 - Down
| Phoneme selection
DH1 - THey
| Phoneme selection
DH2 - baTHe
| Phoneme selection
EH - Extent
| Phoneme selection
EL - angLE
| Phoneme selection
ER1 - intERupt
| Phoneme selection
ER2 - bIRd
| Phoneme selection
EY - grEAt
| Phoneme selection
FF - Food
| Phoneme selection
GG1 - Get
| Phoneme selection
GG2 - Green
| Phoneme selection
GG3 - anGer
| Phoneme selection
HH1 - Help
| Phoneme selection
HH2 - Hope
| Phoneme selection
IH - sIt
| Phoneme selection
IY - trEAt
| Phoneme selection
JH - inJure
| Phoneme selection
KK1 - Clown
| Phoneme selection
KK2 - tasK
| Phoneme selection
KK3 - Crane
| Phoneme selection
LL - Lake
| Phoneme selection
MM - Milk
| Phoneme selection
NG - aNGer
| Phoneme selection
NN1 - thiN
| Phoneme selection
NN2 - Now
| Phoneme selection
OR - stORe
| Phoneme selection
OW - zOne
| Phoneme selection
OY - nOIse
| Phoneme selection
PP - triP
| Phoneme selection
RR1 - WRite
| Phoneme selection
RR2 - gRease
| Phoneme selection
SH - SHip
| Phoneme selection
SS - teSt
| Phoneme selection
TH - THin
| Phoneme selection
TT1 - tesT
| Phoneme selection
TT2 - Test
| Phoneme selection
UH - bOOk
| Phoneme selection
UW1 - cumpUter
| Phoneme selection
UW2 - fOOd
| Phoneme selection
VV - Vest
| Phoneme selection
WH - WHite
| Phoneme selection
WW - Work
| Phoneme selection
XR - haiR
| Phoneme selection
YR - clEAR
| Phoneme selection
YY1 - compUter
| Phoneme selection
YY2 - Yes
| Phoneme selection
ZH - aZure
| Phoneme selection
ZZ - phaSe
| Phoneme selection
ReadPhonemeLength
- STRING
Phoneme
- UINT
EnableOutput
DisableOutput
ReadByteFromPhoneme
- STRING
Phoneme
- UINT
Idx
- BYTE
OutputPhoneme
- STRING
DataString
Phoneme Settings
Phoneme Selection
Phoneme Data Set
Pitch (Hz)
Phoneme Data Size
ROM Size
Base ROM Address
Suggested Address
Output Mode
PWM Pin
PWM Pin
Phoneme Selection
Select All
Select None
PA1 (10ms)
PA2 (30ms)
PA3 (50ms)
PA4 (100ms)
PA5 (200ms)
AA - hOt
| Phoneme selection
AE - hAt
| Phoneme selection
AO - AUght
| Phoneme selection
AR - alARm
| Phoneme selection
AW - sOUnd
| Phoneme selection
AX - Apple
| Phoneme selection
AY - skY
| Phoneme selection
BB1 - Brown
| Phoneme selection
BB2 - Business
| Phoneme selection
CH - CHurCH
| Phoneme selection
DD1 - enD
| Phoneme selection
DD2 - Down
| Phoneme selection
DH1 - THey
| Phoneme selection
DH2 - baTHe
| Phoneme selection
EH - Extent
| Phoneme selection
EL - angLE
| Phoneme selection
ER1 - intERupt
| Phoneme selection
ER2 - bIRd
| Phoneme selection
EY - grEAt
| Phoneme selection
FF - Food
| Phoneme selection
GG1 - Get
| Phoneme selection
GG2 - Green
| Phoneme selection
GG3 - anGer
| Phoneme selection
HH1 - Help
| Phoneme selection
HH2 - Hope
| Phoneme selection
IH - sIt
| Phoneme selection
IY - trEAt
| Phoneme selection
JH - inJure
| Phoneme selection
KK1 - Clown
| Phoneme selection
KK2 - tasK
| Phoneme selection
KK3 - Crane
| Phoneme selection
LL - Lake
| Phoneme selection
MM - Milk
| Phoneme selection
NG - aNGer
| Phoneme selection
NN1 - thiN
| Phoneme selection
NN2 - Now
| Phoneme selection
OR - stORe
| Phoneme selection
OW - zOne
| Phoneme selection
OY - nOIse
| Phoneme selection
PP - triP
| Phoneme selection
RR1 - WRite
| Phoneme selection
RR2 - gRease
| Phoneme selection
SH - SHip
| Phoneme selection
SS - teSt
| Phoneme selection
TH - THin
| Phoneme selection
TT1 - tesT
| Phoneme selection
TT2 - Test
| Phoneme selection
UH - bOOk
| Phoneme selection
UW1 - cumpUter
| Phoneme selection
UW2 - fOOd
| Phoneme selection
VV - Vest
| Phoneme selection
WH - WHite
| Phoneme selection
WW - Work
| Phoneme selection
XR - haiR
| Phoneme selection
YR - clEAR
| Phoneme selection
YY1 - compUter
| Phoneme selection
YY2 - Yes
| Phoneme selection
ZH - aZure
| Phoneme selection
ZZ - phaSe
| Phoneme selection
