| Author
Matrix TSL
| Version
2.0
| Category
Misc
I2C component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the Two Wire I²C peripheral.
Please click here to download the component source project: FC_Comp_Source_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_I2C.fcfx
Slave_Uninit
| Uninitialise the Slave
GetValue
| Get the Named property value.
- STRING
Name
- STRING
Transaction_Write
| Attempt to write Length number of bytes to the I2C slave from the given Buffer. Ensure that the Buffer is large enough. Returns the number of bytes written, the caller should check that this matches requested Length
- BYTE
Buffer
| Buffer of bytes to write to the I2C
- UINT
Length
| Number of bytes to send out, MS bit 0x8000 signifies no Stop if set
- UINT
Master_Stop
| Output a Master Stop
Slave_Init
| Initialise the Slave with the given Address, or range of Addresses. Only address bits that have a corresponding bit set in the Mask will be compared with the incoming bus address.
- BYTE
Address
| 7 Bit Address of this device (Bit 0 is ignored)
- BYTE
Mask
| Bit mask used to compare addresses
Master_Uninit
| Uninitialise the Master
Slave_Status
| Returns the Slave Status. Bit 0 = 1 Indicates address/data byte available in the buffer to read Bit 5 = 1 Indicates that the last byte received or transmitted was data (else address)
- BYTE
GetConsoleHandle
| Obtains the CAL console handle
- HANDLE
Slave_TxByte
| Send a data byte, returns Ack/Nak from Master 0=Ack=More, 1=Nak=Last
- BYTE
Data
- BYTE
Transaction_Uninit
| Uninitialise the I2C interface
Slave_RxByte
| Returns the data received, and sends either Ack or Nak Set parameter Last as: 1=Last=Nak, 0=Ack=More
- BYTE
Last
| Sends Ack if 0, else Nak
- BYTE
SetValue
| Change Named property to new Value. If "CHANNEL" the ports will be also updated from the fcd
- STRING
Name
- STRING
Value
| port value as string
Master_Init
| Initialise the Master
Master_Start
| Output a Master Start sequence
Transaction_Read
| Attempt to read Length number of bytes from the I2C slave to the given Buffer. Ensure that the Buffer is large enough. Returns number of bytes read, caller should check that this matches requested Length
- BYTE
Buffer
| Buffer to store the incoming byte data
- UINT
Length
| Number of bytes to read
- UINT
Master_TxByte
| Send a data byte and collects the acknowledge from the slave. Returns 0 for Ack received. Returns 1 for Ack not received - slave not responding.
- BYTE
Data
| Data byte to write to the I2C bus
- BYTE
Master_Restart
| Output a Master Restart sequence
Master_RxByte
| Returns a received data byte. Set Last=0 if there is following more Master_RxByte macros Set Last=1 if this is the last Master_RxByte and it is followed with Master_Stop. If Last = 1 the I2C bus will be presented with a 'Nack' condition.
- BYTE
Last
| Range: 0-1 - 0 = Not the last byte to receive, 1 = last byte to receive
- BYTE
Transaction_Initialise
| Initialise the I2C interface to communicate with a Slave device at Address Returns 0 on fail, 1 on success
- BYTE
Address
| 7-bit I2C Address without the shift for the R/W bit
- BYTE
GetList
| returns Named property List as filter string
- STRING
Name
- STRING
Component Enable
| Allows the component to be easily disabled from generating code, allowing for multiple CAL components to be easily created. For example a sensor IC with both I2C and SPI communications interfaces.
| Channel selection
Mode
| Defines if the component will be used for Master or Slave communications. Master mode supports a software bitbanged I2C channel. Slave mode requires a hardware I2C peripheral to catch the communications from the Master.
SDA
SCL
Options
Stop Delay
Baud Select
| Baud rate option selector
| Baud rate to be used
Slew Rate Control
| Slew Rate Control Enabled or Disabled
SMBus Inputs
| When Enabled input logic thresholds are compliant with SMBus specification
| Selects if the component pin connections are automatically generated on the data recorder window or not. Yes: Automatically add the component pins to a group on the data recorder which will reflect the sim data during simultion. No: Do not show the pin signals on the data recorder window.
API
| Specifies the API component on the panel to interact with to provide comms simulation.
