Component: Temperature Sensor (Grove 101020015) (101020015) (Environmental)
Jump to navigationJump to search| Author | Matrix Ltd |
| Category | Environmental |
Temperature Sensor (Grove 101020015) component
Temperature Sensor uses a thermistor to measure ambient temperature. The resistance of thermistor changes based on ambient temperature. This resistance value alters the output of a voltage divider which is measured by an analog input pin and converted to a temperature value. The operating range is -40 to 125°C , with an accuracy of 1.5°C .
Please click here to download the component source project: FC_Comp_Source_TemperatureSensor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TemperatureSensor.fcfx
| GetTempInt | |
| Reads the temperature of the temperature sensor and returns as an integer value. | |
| GetTempFloat | |
| Reads the temperature of the temperature sensor and returns as a floating point value. | |
