Component: UART Software (Timer) (Comms: Interface)
Revision as of 16:50, 30 January 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Comms: Interface
UART Software (Timer) component
Creates a reliable software UART that can be driven using a timer interrupt setup by the user. The timer interrupt must be interrupting at the required baud rate. e.g 9600Hz.
Please click here to download the component source project: FC_Comp_Source_UART_Software_Timer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_UART_Software_Timer.fcfx
Simple example showing how to enable a timer interrupt at the desired baud rate then receive a string. If anything is received then it will be echoed back out and displayed on a LCD
UART_Timer_Example
SendString
Sends an string to the transmit buffer
- STRING Data
ReceiveArray
Gets an array of values from the receive buffer. Returns number of values received.
- UINT Values
- UINT NumValues
- UINT Timeout
Time in milliseconds to wait for data
SendArray
Sends an array of values to the transmit buffer
- UINT Values
- UINT NumValues
UART_Timer_Process
Called as part of a timer interrupt at the specific UART baud rate.
ReceiveValue
Gets a single value from the receive buffer
- UINT Timeout
SendValue
Sends a single value to the transmit buffer
- UINT Value
CheckBuffer
Returns the number of values in the transmit or receive buffer
- BOOL Buffer
0=Transmit / 1=Receive
ReceiveString
Gets a string from the receive buffer
- UINT MaxChars
- UINT Timeout
- STRING Return
Initialises the UART component pins ready to send and receive data
Global Settings
Data Bits
Stop Bits
Use TX
Allows the Transmit pin to be enabled / disabled
Use RX
Allows the Receive pin to be enabled / disabled
Transmit Properties
Transmit Pin
Pin assigned to transmitting data
Transmit Buffer Size
Number of bytes that can be stored in the outgoing transmit buffer
Receive Properties
Receive Pin
Pin assigned to receiving data
Receive Buffer Size
Number of bytes that can be stored in the incoming receive buffer
API
