API Panel.Position.GetQuat
Revision as of 21:05, 19 May 2013 by (username removed)
<sidebar>API contents</sidebar> Returns the positions quaternion in {X,Y,Z,W} array
Class hierarchy
Panel
Position
GetQuat
HANDLE Handle
The position or component to read
HANDLE Target
The position or component to convert relative to
FLOAT[]
  • Declare a variable 'result' of type FLOAT[]
  • Add to a calculation icon:
    result = ::Panel.Position.GetQuat(handle, target)
Flowcode example file
Download File:SIMAPI Panel Position GetQuat.fcf and open it in Flowcode v6. In this example a blue cuboid and a LCD are shown on the system panel. When the program starts, a Quaternion of the cuboid is returned into an existing Float Array variable. The Quaternion values are then displayed on the LCD display.
The screenshots below show the effect and also highlight the code used by the example.
