Component: Heelight Sensor (Grove 101020312) (101020312) (Audio)
Revision as of 12:01, 3 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Audio
Heelight Sensor (Grove 101020312) component
Heelight Sensor is a smart voice sensor that can recognize up tp 500 digital voice commands. It was originally used on the Heelight – a smart colorful bulb that can be controlled by digital sound waves. Allows you to realize smart control in your own projects. Compatible with Heelight smart phone apps and other Heelight controllers.
Please click here to download the component source project: FC_Comp_Source_temp/Heelight_Sensor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Heelight_Sensor.fcfx
Sets up the UART peripheral ready to receive messages from the Heelight sensor.
ListenForCommand
ListenForCommand
Listens for a Heelight command with timeout. Returns 1 if a command received. Returns 0 if no command was received.
- BYTE Timeout
0=Don't Wait, 1-254=MilliSec Delay, 255=Wait Forever
ReadData
ReadData
Reads data received from the listen macro.
- BYTE Index
Data Byte Received Range: 0-3
UART Channel selector
TX
RX
Baud Options
Console Columns
Data Source
