Component: SCADA (Dummy) (SCADA Slaves)
| Category | SCADA Slaves |
SCADA (Dummy) component
Dummy SCADA Slave component to enable injector referencing. Supports: Digital IO / ADC / I2C / SPI / PWM See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_temp/OLD_API_Slave_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/OLD_API_Slave_Dummy.fcfx
I2CInitialise
| I2CInitialise | |
| Initialsie the I2C module ready for communications | |
I2CReceive
| I2CReceive | |
| Receive a byte using the I2C bus | |
| Last | |
I2CRestart
| I2CRestart | |
| Put the I2C Module into Restart mode | |
I2CSend
| I2CSend | |
| DataOut | |
I2CStart
| I2CStart | |
| Put the I2C Module into Start mode | |
I2CStop
| I2CStop | |
| Put the I2C Module into Stop mode | |
IOGetInputPin
| IOGetInputPin | |
| Pin | |
| Range: 0-13 | |
IOSetOutputPin
| IOSetOutputPin | |
| Pin | |
| Range: 0-13 | |
| State | |
| Range: 0-1 | |
SPIInitialise
| SPIInitialise | |
SPIPrescaler
| SPIPrescaler | |
| Modify the speed of the SPI bus | |
| Prescaler | |
| Range: 0-2 | |
SPITransfer
| SPITransfer | |
| Transfer a byte using the SPI bus | |
| DataOut | |
| Properties |
