Component: Switch (Push, Panel) ()
Revision as of 12:04, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.1
Category
Switch (Push, Panel) component
Large round push switch with chrome bezel for panel mounting.
Please click here to download the component source project: FC_Comp_Source_temp/sw_push_rnd_pnl.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/sw_push_rnd_pnl.fcfx
Here is an example Flowcode program to read the value of a switch. FC6 Icon.png Switch
(5V / 11K) * 10K = 4.54545V
Fc9-type-5-icon.png Connection
Chip pin to which this switch is connected.
Fc9-type-16-icon.png Polarity
Sets whether activating the switch sets the chip pin high or low.
Fc9-type-14-icon.png Debounce (ms)
Time in milliseconds allowed for the switch to stabilise after a change of state. NB) This applies only when using the component macros to read the button state- chip pin is not debounced.
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Operation
Latching - click the button to turn the switch on, click again to turn it off. Momentary - click the button to turn it on, release the mouse to turn it off.
