Component: G Code Parser ()
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 1.1 |
| Category |
G Code Parser component
A set of routines to allow a G-Code type file to be parsed a line at a time and the coordinates to be collected. Simulates the G commands via a simulation only 3D printer component but can also be used to pass values to actual hardware.
Please click here to download the component source project: FC_Comp_Source_temp/G-Code_Parser.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/G-Code_Parser.fcfx
GetAxis
GetCoordinateMode
|   | GetCoordinateMode |
| Returns the current coordinate mode. 0 = Absolute 1 = Relative | |
|  - BYTE | Return |
|   | Initialise |
|  - VOID | Return |
Parse_G_Command
|   | Parse_G_Command |
|  - STRING | Command |
|  - VOID | Return |
|   | Properties |
|   | Bed Color |
|   | Print Color |
|   | Print Speed |
|   | Print Type |
|   | Print Size |
|   | Print Shape |
|   | Max Print Dimensions |
|   | X Width |
|   | Y Length |
|   | Z Height |
