| Author
Matrix Ltd
| Version
1.6
| Category
Graphical Monochrome
GLCD (ST7036) I2C component
Graphical display component based on the I2C version of the ST7036 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 1K of graphical memory using the microcontroller's RAM memory.
Please click here to download the component source project: FC_Comp_Source_temp/GLCD_ST7036_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/GLCD_ST7036_I2C.fcfx
BPlot
BPlot
- UINT
X1
- UINT
Y1
ClearDisplay
ClearDisplay
ControlContrast
ControlContrast
| Sets the display contrast from 0 to 255.
- BYTE
Contrast
| Range 0 - 255, Default 207
ControlDisplay
ControlDisplay
| Allows the display to be switched on and off
- BYTE
Control
| 0=Off, 1=On
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
InvertDisplay
InvertDisplay
Plot
Plot
- UINT
X1
- UINT
Y1
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SendCommand
SendCommand
- BYTE
Command
SetBackgroundColour
SetBackgroundColour
- BYTE
PixelColour
| 0=White, 1=Black
SetDisplayOrientation
- BYTE
Orientation
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SetForegroundColour
SetForegroundColour
- BYTE
PixelColour
| 0=White, 1=Black
Dimensions
Pixel Width
Pixel Height
Interlaced
| Determines if the display is interlaced in the Y axis or not
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
| Channel selection
Baud Select
| Baud rate option selector
| Baud rate to be used
Stop Delay
SDA
SCL
Reset Pin
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Physical Orientation
Simulate Comms
| Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
