Component: Digital Potentiometer (X9Cx0x) (Analog Output)
Revision as of 12:22, 3 February 2023 by Wiki bot (talk | contribs)
Category Analog Output
Digital Potentiometer (X9Cx0x) component
The X9Cx0x device range supports a digital potentiometers outputs. 100 possible wiper tap points available. Supported devices include X9C102, X9C103, X9C104, X9C503.
Please click here to download the component source project: FC_Comp_Source_temp/X9C_Digital_Pot.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/X9C_Digital_Pot.fcfx
DecrementWiper
DecrementWiper
Decrements a single volatile wiper value
DecrementXTimes
DecrementXTimes
Decrements the wiper value the specified number of times
- BYTE Count
Range: 1-99
IncrementWiper
IncrementWiper
Increments a single volatile wiper value
IncrementXTimes
IncrementXTimes
Increments the wiper value the specified number of times
- BYTE Count
Range: 1-99
Device Connections
CS Pin
Chip Select Pin, Active Low
Increment Pin
Increment Pin, Active Low
Up/Down Pin
Up Down Pin, Low = Down, High = Up
