Component: XML JSON Parser (Runtime Tools)
Jump to navigationJump to search| Author | MatrixTSL |
| Category | Runtime Tools |
- 1 XML JSON Parser component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 AddObject
- 5.2 BuildJSONString
- 5.3 BuildXMLString
- 5.4 ClearObjects
- 5.5 DeleteObject
- 5.6 FindNextObject
- 5.7 FindNextObjectString
- 5.8 FindObject
- 5.9 FindObjectString
- 5.10 GetObjectString
- 5.11 GetObjectTag
- 5.12 GetRootHandle
- 5.13 ParseJSONDataString
- 5.14 ParseXMLDataString
- 5.15 SetObjectString
- 5.16 SetObjectTag
- 6 Property reference
A component designed to simplify the collection of data from XML and JSON sources. Parses the raw data and creates a dynamic representation of the data that is easy to navigate and interrogate. Also allows the objects to be manually created or edited and then re-exported as XML or JSON format.
Please click here to download the component source project: FC_Comp_Source_temp/XMLParser.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/XMLParser.fcfx
AddObject
BuildJSONString
|   | BuildJSONString |
| Generate a JSON string based on the current objects inside the component. | |
|  - STRING | Return |
BuildXMLString
|   | BuildXMLString |
| Generate a XML string based on the current objects inside the component. | |
|  - STRING | Return |
ClearObjects
|   | ClearObjects |
| Deletes all object data ready for fresh input | |
|  - VOID | Return |
DeleteObject
|   | DeleteObject |
| Deletes a selected tag object. | |
|  - HANDLE | Object |
| Handle to the object | |
|  - BOOL | Return |
FindNextObject
|   | FindNextObjectString |
| Searches for and then collects the data string from the specified path. Returns the first matching path from the last search | |
|  - STRING | SubObjPath |
| e.g. "item.title" | |
|  - STRING | Return |
FindObject
|   | FindObject |
| Finds the first instance of an object. Returns the first matching path from the root. Returns 0 if the path was not found. | |
|  - STRING | ObjPath |
| e.g. "rss.channel.title" | |
|  - HANDLE | Return |
FindObjectString
|   | FindObjectString |
| Searches for and then collects the data string from the specified path. Returns the first matching path from the root. | |
|  - STRING | Return |
GetObjectString
|   | GetObjectString |
| Collects the data string from the specified object. | |
|  - HANDLE | Object |
|  - STRING | Return |
GetObjectTag
|   | GetObjectTag |
| Collects the tag string from the specified object. | |
|  - HANDLE | Object |
|  - STRING | Return |
GetRootHandle
|   | GetRootHandle |
| Allows for user to step through the objects manually using the inbuilt runtime api calls. | |
|  - HANDLE | Return |
ParseJSONDataString
ParseXMLDataString
SetObjectString
|   | SetObjectString |
| Sets the data string of an existing object. | |
|  - HANDLE | Object |
|  - STRING | Data |
|  - VOID | Return |
SetObjectTag
|   | SetObjectTag |
| Sets the tag name of an existing object. | |
|  - HANDLE | Object |
|  - STRING | Tag |
|  - VOID | Return |
|   | Properties |
