Component: Switch Array Template (Development)
| Author | Matrix Ltd. |
| Version | 2.0 |
| Category | Development |
Switch Array Template component
A base component for creating an evenly spaced array of switches. Each will be connected to sequential pins of a given I/O port. Set target object to point at any standard switch component to change the type of switch used by the array.
Please click here to download the component source project: FC_Comp_Source_temp/switch_array.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/switch_array.fcfx
Here is an example Flowcode program to read the values of a switch array.
 Switch Array
Switch Array
The resistors are required for correct operation because when a microcontroller's input pin is essentially connected to nothing it will pick up noise in the environment and provide inconsistent readings. This state is referred to as floating i.e. the pin is floating. To test this remove the resistors (if possible) and touch the unconnected switch pins with your finger the output LEDs from the example file above will toggle on and off at high speed.
(5V / 11K) * 10K = 4.54545V
GetHandle
|   | GetHandle |
| Retrieves the object handle of the switch component at the given index. | |
|  - BYTE | Index |
|  - HANDLE | Return |
ReadAll
|   | ReadAll |
| Reads all of the switches at once, returning a byte containing one bit per switch. | |
|  - BYTE | Return |
ReadState
|   | ReadState |
| Read the state of the switch at the given index. | |
|  - BYTE | Index |
| The switch to read the status of. | |
|  - BOOL | Return |
WaitUntilHigh
|   | WaitUntilHigh |
| Pause the program until the switch at the given index is turned on. | |
|  - BYTE | Index |
| Index of the switch to wait for. | |
|  - VOID | Return |
WaitUntilLow
|   | WaitUntilLow |
|  - BYTE | Index |
|  - VOID | Return |
