| Author
Matrix Ltd.
| Version
1.0
| Category
Electrical
Energy Monitor (PZEM-004T) component
The PZEM-004T module is used for measuring AC voltage, current, active power, frequency, power factor & overcurrent. Resetable active energ and the overpower level can be set and monitored.
Please click here to download the component source project: FC_Comp_Source_Energy_Monitor_PZEM-004T.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Energy_Monitor_PZEM-004T.fcfx
Note if there is a communication issue then just 9's will be returned!
Example program that uses a PZEM-004T energy monitor to monitor mains voltage, current, frequency, power factor, energy, and over specified power alarm.
The alarm threshold is set within properties.
Initialiasion returns 0 if PZEM-004T is detected or 255 if it is not.
Values are sent to the ESP32 TTGO display which uses a ST7789v1 GLCD.
ESP32 TTGO Mains PM v1.3
| Starts up the UART to allow communications. Also, checks if PZEM-004T is detected. Returns 0 if detected or 255 if not detected.
- BYTE
ReadAlarmStatus
ReadAlarmStatus
| 65535 = Overpower alarm triggered. 0 = Overpower alarm not triggered.
- UINT
ReadCurrent
ReadCurrent
| Read what the current draw is. Resolution: 0.001A Measurement accuracy: 0.5%
- FLOAT
ReadEnergy
ReadEnergy
| Read active energy value. Resolution: 1Wh Measurement accuracy: 0.5%
- FLOAT
ReadFrequency
ReadFrequency
| Reads the frequency of the mains
- FLOAT
ReadPower
ReadPower
| Read active power. Starting measure power: 0.4W Resolution: 0.1W
- FLOAT
ReadPowerAlarmThreshold
| Reads the power alarm threshold in watts
- UINT
ReadPowerFactor
ReadPowerFactor
| Read power factor Resolution: 0.01 Measurement accuracy: 1%
- FLOAT
ReadVoltage
ReadVoltage
| Read voltage. Measuring range:80~260V Resolution: 0.1V Measurement accuracy: 0.5%
- FLOAT
ResetEnergy
ResetEnergy
| Reset the energy value
- BYTE
SetPowerThresholdLevel
| Sets the power alarm threshold in watts
- UINT
PowerThresholdValue
| Reg addreess high of alarm threshold
- BYTE
UART Properties
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
TX
| Pin to be used for Transmit data
RX
| Pin to be used for Receive data
Baud Options
| Baud rate option selector
Bus
| Specifies the bus mode being used, RS232 allows you to connect a single master node to a single slave node. RS485 allows you to connect a single master node to multiple slave nodes.
Modbus Properties
Receive Buffer Size
| Maximum number of bytes the receive buffer can hold
Slave ID Bytes
| Number of bytes used when passing a slave ID, usually 1 but sometimes 2
Silent Interval
| Configures how much time to wait after each master modbus command before another command can be sent. A silent interval of 60ms minimum is required in order to guarentee successful reception of the next transmission. 0=No Delay 60 = 60mS - Default Range : 0 - 65535
UART Receive Timeout
| Amount of time to wait before timing out when listening for a slave's response. Range: 0 - 255. 0 = Don't Wait 1 - 254 = X ms 255 = Wait Forever
Receive Timeout Count
| Number of timeouts in a row to wait for until we decide the slave is not responding or finished responding to a message. Range: 0 - 255 0 = First Timeout Only 1 = First Timeout + 1 2 = First Timeout + 2
Simulation Properties
| A text label to appear on the Modbus panel object.
| Selects if the scope traces are automatically added to the data recorder window or not. Simulation - draws an approximation of the UART data onto the scope trace. ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data API component on the Panel.
