Component: Pulse Oximeter (Max30100) (Environmental)
Revision as of 13:12, 7 February 2023 by Wiki bot (talk | contribs)
Category Environmental
Pulse Oximeter (Max30100) component
Sensor designed to monitor heart rate and pulse omimetry. Connected using an I2C bus.
Please click here to download the component source project: FC_Comp_Source_Max30100_Pulse_Oximeter.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Max30100_Pulse_Oximeter.fcfx
Fc9-comp-macro.png Initialise
Sets up the I2C bus ready for communications with the sensor IC. Must be called once before calling any of the other component macros. Applies the defauilt settings from the component properties.
ReadIR
Fc9-comp-macro.png ReadIR
Returns one of the FIFO IR readings from the last update
ReadRed
Fc9-comp-macro.png ReadRed
Returns one of the FIFO Red readings from the last update
SetHighResModeEnabled
Fc9-comp-macro.png SetHighResModeEnabled
Fc9-u8-icon.png - BYTE Enabled
SetLEDsCurrent
Fc9-comp-macro.png SetLEDsCurrent
Fc9-u8-icon.png - BYTE IR
Range: 0-15 / 0=0mA, 1=4mA, .., 14=46mA, 15=50mA
Fc9-u8-icon.png - BYTE Red
SetLEDsPulseWidth
Fc9-comp-macro.png SetLEDsPulseWidth
Fc9-u8-icon.png - BYTE PulseWidth
SetSamplingRate
Fc9-comp-macro.png SetSamplingRate
Fc9-u8-icon.png - BYTE SampleRate
Range: 0-7 / 0=50Hz, 1=100Hz, .., 6=800Hz, 7=1000Hz
Update
Fc9-comp-macro.png Update
Reads the sensor FIFO buffer and stores the readings into local RAM. Returns the number of samples read.
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-16-icon.png SDA Remap Pin
Fc9-type-5-icon.png SCL
Fc9-type-16-icon.png SCL Remap Pin
Baud rate to be used
Fc9-conn-icon.png Sensor Defaults
Fc9-type-16-icon.png Sample Rate
Sets the default sample rate
Fc9-type-16-icon.png Pulse Width
Sets the default pulse width and bit depth of the sensor measurements
Fc9-type-7-icon.png High Resolution Mode
Sets if the module defaults to high or low reolution mode
Fc9-type-16-icon.png IR LED Current
Default current to drive the IR LED
Fc9-type-16-icon.png Red LED Current
Default current to drive the Red LED
Fc9-conn-icon.png Simulation
Allows the I2C communications to be simulated and interfaced via an API component to real world hardware.
