Component: WLAN (ESP32) (Comms: Networking)
| Author | Matrix Ltd. |
| Version | 2.4 |
| Category | Comms: Networking |
- 1 WLAN (ESP32) component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 AcceptClose
- 5.2 AcceptOpen
- 5.3 ConnectToSSID
- 5.4 CreateAccessPoint
- 5.5 Disconnect
- 5.6 Initialise
- 5.7 ReadEncryptionModeFromScan
- 5.8 ReadIP
- 5.9 ReadIPString
- 5.10 ReadSSIDFromScan
- 5.11 ReadSignalStrengthFromScan
- 5.12 ScanForSSID
- 5.13 SocketClose
- 5.14 SocketConnect
- 5.15 SocketListen
- 5.16 SocketOpen
- 5.17 SocketRead
- 5.18 SocketWrite
- 5.19 Uninitialise
- 6 Property reference
Wireless LAN component designed to work with ESP32 modules
Please click here to download the component source project: FC_Comp_Source_WLAN_ESP32.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN_ESP32.fcfx
Here is an example of a next-day weather predictor that also shows the current-day weather for a ESP32 embedded device
It uses the BBC weather component via Netwoekcomms and WLAN ESP32 components to connect to the BBC server and retrieve the weather forecast for the specified area code.
AcceptClose
| AcceptClose | |
| Close the socket associated with the Accepted incoming connection | |
AcceptOpen
| AcceptOpen | |
| Returns 1 if there is an incoming connection on the listening port | |
ConnectToSSID
CreateAccessPoint
Disconnect
| Disconnect | |
| Attempts to disconnect from the SSID. | |
| Initialise the WiFi system Returns 1 if successful Returns 0 if not | |
ReadIP
ReadIPString
| ReadIPString | |
| Collects the local IP address and returns it as an ASCII string. e.g. "192.168.0.1" | |
ReadSSIDFromScan
| ReadSSIDFromScan | |
| Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first. | |
| Index | |
| SSID Index | |
ScanForSSID
SocketClose
| SocketClose | |
SocketConnect
| SocketConnect | |
| Address | |
| Port | |
SocketListen
| SocketListen | |
| Listen on, or bind, local port to already opened socket. Returns 1 if OK, 0 if fail | |
| Port | |
SocketOpen
| SocketOpen | |
| Returns 1 if socket sucessfully opened | |
SocketRead
| SocketRead | |
| Buffer | |
| Size | |
SocketWrite
| SocketWrite | |
| Buffer | |
| Size | |
Uninitialise
| Uninitialise | |
| Shuts down the WiFi system for low power operation. Returns 1 if successful Returns 0 if not | |
| Properties | |
| Verbose Debug | |
| Simulation | |
| Network Interface | |
| List of network interfaces connected to the PC. Sets which interface we are communicating via. | |
| Console Data | |
| Generate Console Data | |
