| Author
Matrix Ltd.
| Version
1.3
| Category
Comms: Interface
I2C Slave component
Please click here to download the component source project: FC_Comp_Source_I2C_Slave.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_I2C_Slave.fcfx
PIC16F1937 Examples
The slave device is connected to a bank of switches, the master device to a bank of LEDs. The value of the switches is passed to the master LEDs.
Master Read Example
Slave Switches Example
The slave device is connected to a bank of LEDs, the master device to a bank of switches. The value of the switches is passed to the slave LEDs.
Master Send Example
Slave LEDs Example
Arduino Uno Examples
Example program showing how to use the I2C Slave on an AVR Arduino device.
I2C Slave Arduino Uno Example
ECIO40P Examples
Example program showing how to use the I2C Slave on an ECIO40P device.
Master Example
Slave Example
Check_Status
Check_Status
| Returns the Slave Status. Bit 0 = 1 Indicates address/data byte available in the buffer to read Bit 5 = 1 Indicates that the last byte received or transmitted was data (else address)
- BYTE
| Enables the I²C hardware and performs some initialization. Should be called at the start of the program or at least before any of the other I²C functions are called.
ReceiveByte
ReceiveByte
| Receives a byte from the I²C bus. Returns the data received, and sends either Ack or Nak Set parameter Last as: 1=Last=Nak, 0=Ack=More
- BYTE
Last
| Used to signify the last byte when streaming incoming data. 0=Not last byte, 1=Last Byte
- BYTE
TransmitByte
TransmitByte
| Sends a byte on the I²C bus. Returns the acknowledge if any. 0 represents that data was acknowledged and 1 represents no acknowledge was detected.
- BYTE
Data
| Data byte to send on the I²C bus.
- BYTE
Bus Settings
| Channel selection
Baud Select
| Baud rate option selector
| Baud rate to be used
Stop Delay
Slave Setttings
Slave Address
Mask
| 0 - don't care; 1 - perform match; So address of 0x30 and mask of 0xF0 will allow the slave to respond to addresses of 0x30, 0x31, 0x32, …, 0x3F
SDA
SCL
| Label shown on the comms flasher on the simulation panel.
API
