| Author
Matrix Ltd
| Version
3.1
| Category
Graphical Library
GLCD Base component
Base graphical LCD with simulation only interface to allow graphics to be drawn in simulation. Suitable for inheriting to simplify the creation of further graphical LCD components.
Version information
33, 3.1, 13-06-24, BR, Added user selectable simulated mask for round displays
Font sizes
Standard Fonts
0 = Normal
1 = 2 x Width
2 = 2 x Width and 2 x Height
3 = 2 x Height
Extended Fonts
4 = 2 x Width and 3 x Height
5 = 2 x Width and 4 x Height
6 = 2 x Width and 5 x Height
7 = 2 x Width and 6 x Height
8 = 3 x width
9 = 3 x Width and 2 x Height
10 = 3 x Width and 3 x Height
11 = 3 x Width and 4 x Height
12 = 3 x Width and 5 x Height
13 = 3 x Width and 6 x Height
14 = 4 x width
15 = 4 x Width and 2 x Height
16 = 4 x Width and 3 x Height
17 = 4 x Width and 4 x Height
18 = 4 x Width and 5 x Height
19 = 4 x Width and 6 x Height
20 = 5 x width
21 = 5 x Width and 2 x Height
22 = 5 x Width and 3 x Height
23 = 5 x Width and 4 x Height
24 = 5 x Width and 5 x Height
25 = 5 x Width and 6 x Height
26 = 6 x width
27 = 6 x Width and 2 x Height
28 = 6 x Width and 3 x Height
29 = 6 x Width and 4 x Height
30 = 6 x Width and 5 x Height
31 = 6 x Width and 6 x Height
EBM001 Basic Example
EBM001 gLCD Example File
EBM001 Example
EBM001 Maze Builder
Maze Builder gLCD
3D Manipulations
BPlot
BPlot
- UINT
X1
- UINT
Y1
ClearDisplay
ClearDisplay
DrawArc
DrawArc
| Draws an arc either as an outline or as a filled object.
- UINT
X
| Center X coordinate
- UINT
Y
| Center Y coordinate
- UINT
Radius
| Radius, distance of edge from the centre coordinates
- FLOAT
StartAngle
| Angle to start drawing, in degrees
- FLOAT
EndAngle
| Angle to end drawing, in degrees
- UINT
Resolution
| Number of lines to draw from the center to the outer edge
- BYTE
Transparent
| Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE
Solid
| Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawRectangle
DrawRectangle
| Draws a rectangle with the current foreground colour from pixel loaction X1, Y1 to pixel location X2, Y2.
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
DrawRoundedRectangle
| Draws a rectangle with rounded corners
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
FastPlot
FastPlot
| Sets a pixel with the current foreground colour at current pixel location.
Plot
Plot
- UINT
X1
- UINT
Y1
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
ReadFontByte
ReadFontByte
| Gets a byte from the selected embedded ASCII font data.
- BYTE
Font
- BYTE
Character
| ASCII character for example 'A' or 65
- BYTE
ByteIndex
| Font column Ranging 0-4
- BYTE
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetBackgroundColour
SetBackgroundColour
- BYTE
Red
| 0 - 255 where 0 = no red and 255 = maximum red
- BYTE
Green
| 0 - 255 where 0 = no green and 255 = maximum green
- BYTE
Blue
| 0 - 255 where 0 = no blue and 255 = maximum blue
SetDisplayOrientation
- BYTE
Orientation
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SetForegroundColour
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
Window
Window
| Specifies a specific window in the pixels to draw to.
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Colour
| Specifies the initial foreground colour for shapes and text.
Background Colour
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Show Background Elements
| Show or hide features like the title and background.
Component Label
User Label Text
| Text to display
Component Label Scale
Display Type
Embed Font Set
| Specifies if the font set is included with the embedded downloadable code. Some display types have in an built font and text functions so the embedded font set can be disabled to reduce code overhead. For other display types the embedded font data should be enable to allow the print functions to work correctly.
Num Parents
| Number of parent levels to jump up to get the auto title name. For most GLCDs it will be 1. For most Alpha LCDs it will be 2.
Show GLCD Icon
| Show the GLCD connectivity icon, Set to Yes for GLCDs and No for other none standard things e.g. Alphanumeric LCDs.
TouchHandler
Physical Orientation
AutoRefresh
Round Mask
| Allows a round mask to be applied allowing a circular display to be simulated.
Please click here to download the component source project: FC_Comp_Source_GLCD_base.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_base.fcfx
