Component: LED Array (LEDs)
Revision as of 07:29, 24 September 2024 by MartinW (talk | contribs) (→‎Examples)
Category LEDs
LED Array component
An array of LED indicators equally spaced and complete with labels to indicate their meaning. Embedded can be used to control an 8-bit port or up to 8 individual pins.
Please click here to download the component source project: FC_Comp_Source_LED_Array_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Array_2dgi.fcfx
Example program which uses the point graph macro and loops to create a knight rider effect using the LED array.
FC6 Icon.png LED KnightRider
Example program which reads an analogue value from an analogue input voltage and displays the reading in Binary on the LED array.
FC6 Icon.png LED Count
LEDs can be wired either active high or active low. The LED Array components have a property allowing you to configure which LED type your using.
LED Resistor Calculator Tool
AllOff
Fc9-comp-macro.png AllOff
Turns off all elements
AllOn
Fc9-comp-macro.png AllOn
Turns on all elements
BarGraph
Fc9-comp-macro.png BarGraph
Turns on the first N elements of the array - for generating bar graph metes etc.
Fc9-u8-icon.png - BYTE Length
How many items to light up.
LEDOff
Fc9-comp-macro.png LEDOff
Turn off the selected led.
Fc9-u8-icon.png - BYTE Index
Index of the LED to turn on.
LEDOn
Fc9-comp-macro.png LEDOn
Turn on the selected LED.
PointGraph
Fc9-comp-macro.png PointGraph
Turns on the Indexed LED and turns all others off. Does nothing if the index is out of range.
The LED to show.
WriteValue
Fc9-comp-macro.png WriteValue
Write a number which is presented on the LEDs in binary.
Fc9-u8-icon.png - BYTE Value
Provide a value to be written to the LEDs in binary
Fc9-type-16-icon.png Count
The number of LEDs in the array from 1 to 8.
Fc9-type-16-icon.png Output Mode
Fc9-type-19-icon.png Port
Fc9-type-16-icon.png Polarity
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Switch layout
Fc9-type-21-icon.png Distance between LEDs
Fc9-type-2-icon.png Label colour
Fc9-type-7-icon.png Show Connection Label
If enabled, the pin designation will be shown, e.g. B0.
Fc9-type-7-icon.png Show Pin Value
Pin status of VCC or GND will be shown when enabled and simualtion is running.
Fc9-conn-icon.png Appearance
Fc9-type-16-icon.png Shape
Fc9-type-16-icon.png Colour
Fc9-type-16-icon.png Style
