| Author
Matrix TSL
| Version
1.0
| Category
Comms: System
IO Expander component
Provides 16 digital input/output pins arranged into two 8-bit ports using a SPI bus connection. Multiple expanders can be connected to the same SPI peripheral by means of individual chip select pins.
More information on I2C can be found here,
Generic I2C EEPROM
Example file demonstrating how to read and write bytes from a generic I2C EEPROM device.
I2CEEPROM
Simulated I2C devices
I2C DS1307 Example
ReadPort
| Reads a value to one of the ports with a mask. Configures the masked bits to be inputs before reading the input value.
  - BYTE
Port
| 0=PortA, 1=PortB
  - BYTE
Mask
| Allows port bits to be modified without effecting other bits, 255 = write full port.
  - BYTE
ConfigureInversion
| Configures the pin inversion for the two ports.  Disabled on all pins by default.
  - BYTE
PortA
| Port A inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
  - BYTE
PortB
| Port B inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ReadPortPin
| Reads a single port pin from one of the ports. Configures the pins to be an input before reading the input value. Returns 0 or 1 corresponding to the value on the port pin.
  - BYTE
Port
| 0=PortA, 1=PortB
  - BYTE
Pin
| Port pin to read. Range: 0-7
  - BYTE
WritePortPin
| Writes a single port pin on one of the ports. Configures the pins to be an output before writing the input value.
  - BYTE
Port
| 0=PortA, 1=PortB
  - BYTE
Pin
  - BYTE
Value
| Value to output on the selected pin. Range: 0-1
WritePort
| Writes a value to one of the ports with a mask. Configures the masked bits to be outputs before writing the output value.
  - BYTE
Port
| 0=PortA, 1=PortB
  - BYTE
Mask
  - BYTE
Value
| Value to write. Range 0-255
ConfigurePullups
| Configures the pullups for the two ports. Disabled on all pins by default.
  - BYTE
PortA
| Port A pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
  - BYTE
PortB
| Port B pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ReadRegister
| Reads an 8-bit value from a register on the I/O expander device.
  - BYTE
Address
| Register address to write to. Range: 0-15
  - BYTE
WriteRegister
| Writes an 8-bit value to a register on the I/O expander device.
  - BYTE
Address
  - BYTE
Value
| Value to write. Range: 0-255
| Enables the I²C hardware and performs some initialization. Should be called at the start of the program or at least before any of the other I²C functions are called.
CheckNetworkStatus
| Returns the state of the GSM network. 0 = Not connected, 1 = connected, 255 = no reply from GSM.
  - BYTE
CheckForIncoming
| Checks to see if any incoming phone call or SMS message. 0 = Nothing, 1 = Text Received, 2 = Phone Ringing
  - BYTE
| Sets up the GSM module. Returns 0 for OK, 255 for no reply and 254 for command fail.
  - BYTE
External Address
| Selects the value of the three address pins for the MCP23S17.
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MISO
CLK
CS / SS
| Chip Select / Slave Select Pin  Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
Use Reset
Simulations
API
