Library Updates
Library Updates
can be accessed via the Help ribbon or when you first open Flowcode
If you select Library Updates via the Help ribbon, then you will have a dropdown giving you the options of either Files in-use or Full database
If required you can rollback a component to an earlier version.
To do that for your current project make sure Files in-use is selected.
Select Show up-to-date files.
You will see Filename, Current Revision, New Revision & Size
Scroll down to the component/file you wish to rollback and select it via the tickbox to the left of its name.
Select the required version within New Revision column, then left-click on Download
Close the library updates window, then left-click on the Reload icon
at the top, or File menu, Reload.
