Component: Switch (Controls)
Author Steve Tandy
Category Controls
Switch component
A 2d switch component.
FREE
Here is an example Flowcode program to read the value of a switch. Switch
The polarity setting within the switch properties determines how the relevant bit of the input variable responds when a switch changes state. This applies only when using switch functions and not when using input command icons.
  • Active High Polarity: When the switch is closed, the voltage on the pin transitions from 0V to the positive supply voltage (either 3.3V or 5V, depending on the microcontroller). As a result, the corresponding bit in the input variable changes from 0 to 1. A pull-down resistor is required for the input pin to ensure it stays at 0V when the switch is open.
  • Active Low Polarity: When the switch is closed, the voltage on the pin transitions from the positive supply voltage to 0V, and again, the relevant bit of the input variable changes from 0 to 1. A pull-up resistor is required for the input pin to ensure it stays at the positive supply voltage when the switch is open.
(5V / 11K) * 10K = 4.54545V
GetState
Reads the state of the switch (true = on, false = off)
- BOOL Return
SetState
Sets the switch to be on or off.
- BOOL bState
The new state of the switch (true=on, false=off)
State
Style
Type
On Label
Off Label
Background Colour
Simulations
