| Author | Matrix Ltd |
| Version | 1.6 |
| Category | E-blocks 2 |
Colour GLCD (BL0157) component
Graphical display component designed to work with the BL0157 E-block. Based on the ILI9163C 16-bit colour graphical controller IC.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_Colour_GLCD_BL0157.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Colour_GLCD_BL0157.fcfx
A simple example that shows how to use some common functions.
Now can take advantage of SPI faster speed, instead of bit banging
 BL0157 Example
BL0157 Example
BL0157 Maze Builder
 Maze Builder gLCD
Maze Builder gLCD
Example to draw a randomly generated 2D maze on an BL0157 graphical display.
BL0157 Drawing 3D Objects With Perspective
 3D Manipulations
3D Manipulations
BPlot
|   | BPlot |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
BacklightOff
|   | BacklightOff |
| Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed. |
|  - VOID | Return |
BacklightOn
|   | BacklightOn |
| Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed. |
|  - VOID | Return |
ClearDisplay
|   | ClearDisplay |
|  - VOID | Return |
DrawCircle
|   | DrawCircle |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | Radius |
|  - BYTE | Transparent |
|  - BYTE | Solid |
|  - VOID | Return |
DrawEllipse
|   | DrawEllipse |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | XRadius |
|  - UINT | YRadius |
|  - BYTE | Solid |
|  - VOID | Return |
DrawLine
|   | DrawLine |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - VOID | Return |
DrawRectangle
|   | DrawRectangle |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - BYTE | Solid |
|  - VOID | Return |
FastPlot
|   | FastPlot |
| Sets a pixel with the current foreground colour at current pixel location. Not compatible with orientations other than 0. |
|  - VOID | Return |
|   | Initialise |
|  - VOID | Return |
Plot
|   | Plot |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
Print
|   | Print |
|  - STRING | Str |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - BYTE | Font |
|  - VOID | Return |
|   | PrintNumber |
|  - INT | Number |
|  - UINT | X |
|  - UINT | Y |
|  - BYTE | Font |
|  - VOID | Return |
ReadFontStat
|   | ReadFontStat |
|  - BYTE | Font |
|  - BYTE | Index |
|  - BYTE | Return |
ReadFontWidth
|   | ReadFontWidth |
|  - BYTE | Font |
|  - BYTE | Character |
|  - BYTE | Return |
SetBackgroundColour
|   | SetBackgroundColour |
| Specifies the colour of the background by creating a mixture of red, green and blue. |
|  - BYTE | Red |
| 0 - 255 where 0 = no red and 255 = maximum red |
|  - BYTE | Green |
| 0 - 255 where 0 = no green and 255 = maximum green |
|  - BYTE | Blue |
| 0 - 255 where 0 = no blue and 255 = maximum blue |
|  - VOID | Return |
SetDisplayOrientation
|   | SetDisplayOrientation |
|  - BYTE | Orientation |
|  - VOID | Return |
SetFontScaler
|   | SetFontScaler |
|  - BYTE | ScaleX |
|  - BYTE | ScaleY |
|  - VOID | Return |
SetForegroundColour
|   | SetForegroundColour |
| Specifies the colour of the foreground by creating a mixture of red, green and blue. |
|  - BYTE | Red |
|  - BYTE | Green |
|  - BYTE | Blue |
|  - VOID | Return |
Window
|   | Window |
| Specifies a full screen or sub window of pixels to draw. Useful when used with the FastPlot function to draw bitmaps at high speed. |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - VOID | Return |
|   | Properties |
|   | Dimensions |
|   | Pixel Width |
|   | Pixel Height |
|   | Colour |
|   | Monochrome |
|   | Foreground Color |
|   | Background Color |
|   | Bit Depth |
|   | Colour Bit Depth |
|   | Red Bit Depth |
|   | Green Bit Depth |
|   | Blue Bit Depth |
|   | Connections |
|   | Data |
| Data pin connection |
|   | Clock |
| Clock pin connection |
|   | Chip Select |
| Chip select pin connection |
|   | A0 |
| Instruction / Command pin connection |
|   | Reset |
| Reset pin connection |
|   | LED |
| LED backlight strobe pin connection |
|   | Fonts |
|   | Font Count |
|   | Font 0 |
|   | Font |
|   | Character Spacing |
|   | Space Width |
|   | Simulation Mode |
|   | Display Method |
| Chooses which method to use when drawing to the gLCD component The bitmap is the more common mode but may run slowly on some machines. The point cloud should run faster but may use more memory. |
