| Author | Matrix Ltd |
| Version | 1.3 |
| Category | E-blocks 1 |
GLCD (EB043 v1) component
Graphical display component designed to work with the legacy version 1 EB043 E-blocks.
Version information
EB043 v1 gLCD Example File
 EB043 Example
EB043 Example
BPlot
|   | BPlot |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
ClearDisplay
|   | ClearDisplay |
|  - VOID | Return |
DrawArc
|   | DrawArc |
| Draws an arc either as an outline or as a filled object. |
|  - UINT | X |
| Center X coordinate |
|  - UINT | Y |
| Center Y coordinate |
|  - UINT | Radius |
| Radius, distance of edge from the centre coordinates |
|  - FLOAT | StartAngle |
| Angle to start drawing, in degrees |
|  - FLOAT | EndAngle |
| Angle to end drawing, in degrees |
|  - UINT | Resolution |
| Number of lines to draw from the center to the outer edge, 0=Fill |
|  - BYTE | Transparent |
| Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data. |
|  - BYTE | Solid |
| Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour. |
|  - VOID | Return |
DrawCircle
|   | DrawCircle |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | Radius |
|  - BYTE | Solid |
|  - VOID | Return |
DrawEllipse
|   | DrawEllipse |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | XRadius |
|  - UINT | YRadius |
|  - BYTE | Solid |
|  - VOID | Return |
DrawLine
|   | DrawLine |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - VOID | Return |
DrawRectangle
|   | DrawRectangle |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
| Chooses the transparency of the box - 0 = Box contains background colour, 1 = Box contains previous pixel data |
|  - BYTE | Solid |
|  - VOID | Return |
|   | DrawRoundedRectangle |
| Draws a rectangle with rounded corners |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - UINT | Radius |
|  - BYTE | Solid |
|  - VOID | Return |
FastPlot
|   | FastPlot |
| Sets a pixel with the current foreground colour at current pixel location. Not compatible with orientations other than 0. |
|  - VOID | Return |
|   | Initialise |
|  - VOID | Return |
Plot
|   | Plot |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
Print
|   | Print |
|  - STRING | Str |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - BYTE | Font |
|  - VOID | Return |
|   | PrintNumber |
|  - INT | Number |
|  - UINT | X |
|  - UINT | Y |
|  - BYTE | Font |
|  - VOID | Return |
ReadFontStat
|   | ReadFontStat |
|  - BYTE | Font |
|  - BYTE | Index |
|  - BYTE | Return |
ReadFontWidth
|   | ReadFontWidth |
|  - BYTE | Font |
|  - BYTE | Character |
|  - BYTE | Return |
SetBackgroundColour
|   | SetBackgroundColour |
| Specifies the colour of the background by creating a mixture of red, green and blue. |
|  - BYTE | Red |
| 0 - 255 where 0 = no red and 255 = maximum red |
|  - BYTE | Green |
| 0 - 255 where 0 = no green and 255 = maximum green |
|  - BYTE | Blue |
| 0 - 255 where 0 = no blue and 255 = maximum blue |
|  - VOID | Return |
SetDisplayOrientation
|   | SetDisplayOrientation |
|  - BYTE | Orientation |
|  - VOID | Return |
SetFontScaler
|   | SetFontScaler |
|  - BYTE | ScaleX |
|  - BYTE | ScaleY |
|  - VOID | Return |
SetForegroundColour
|   | SetForegroundColour |
| Specifies the colour of the foreground by creating a mixture of red, green and blue. |
|  - BYTE | Red |
|  - BYTE | Green |
|  - BYTE | Blue |
|  - VOID | Return |
Window
|   | Window |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - VOID | Return |
|   | Properties |
|   | Dimensions |
|   | Pixel Width |
|   | Pixel Height |
|   | Colour |
|   | Monochrome |
|   | Foreground Color |
|   | Background Color |
|   | Bit Depth |
|   | Colour Bit Depth |
|   | Red Bit Depth |
|   | Green Bit Depth |
|   | Blue Bit Depth |
|   | Connections |
|   | Data |
| Data pin connection |
|   | Clock |
| Clock pin connection |
|   | Chip Select |
| Chip select pin connection |
|   | Reset |
| Reset pin connection |
|   | Fonts |
|   | Font Count |
|   | Font 0 |
|   | Font |
|   | Character Spacing |
|   | Space Width |
|   | Simulation |
|   | Component Label |
|   | Component Label Scale |
| The label scale can be change if the amout of text is too wide for the display |
|   | Physical Orientation |
Please click here to download the component source project: FC_Comp_Source_GLCD_EB043-00-1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_EB043-00-1.fcfx
