Selecting a Template
Revision as of 11:25, 29 November 2022 by MartinW (talk | contribs)
To open a template simply select the 'NEW PROJECT' on the 'Start Page' window.
Select the 'Templates' tab, then select the required template.
Finally, select the button above that has the name of the selected template (Green Rectangle).
Templates are used to aid the user to work more efficiently and allow the user to expand programs much easier and create a common base to work from, it allows you to start a document with preset configurations, flowchart icons and components.
Templates load up a pre-defined program for the user to expand upon, this provides a quick and easy method of starting projects and starting working immediately instead of having to configure the settings of the chip each time, this is especially useful when switching chips, once you have your preset templates you can skip having to change the settings individually each time you change chip.
You can create your own template by selecting the file type by simply saving a .fcfx Flowcode project file in the 'templates' folder.
This will allow you to create your own custom template to load up in Flowcode using the 'Load Template' window.
