Component: Potentiometer (Colour) ()
Revision as of 11:28, 18 July 2025 by SteveT (talk | contribs) (Added 'Old Versions' section)
Version 1.3
Category
Potentiometer (Colour) component
Potentiometer with black plastic knob with coloured cap. Cap and pointer colours can be changed in component properties.
Old Versions
This page is current for Flowcode v10 and later. Earlier versions can be found below:
Please click here to download the component source project: FC_Comp_Source_pot_Colour.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_pot_Colour.fcfx
Potentiometer Example
Start Angle
Sweep Angle
Cap Color
Colour of the knob cap.
Pointer Color
Colour of the knob pointer.
Retain Value
If yes is slected After saving your project, the ADC value will be retained when your project is reloaded.
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
