Component: GLCD (ST7036) I2C (ST7036) (Graphical Monochrome)
Revision as of 08:59, 9 June 2025 by Wiki bot (talk | contribs)
Version 1.6
Category Graphical Monochrome
GLCD (ST7036) I2C component
Graphical display component based on the I2C version of the ST7036 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 1K of graphical memory using the microcontroller's RAM memory.
Version information
BPlot
Fc9-comp-macro.png BPlot
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
ClearDisplay
ControlContrast
Fc9-comp-macro.png ControlContrast
Sets the display contrast from 0 to 255.
Fc9-u8-icon.png - BYTE Contrast
Range 0 - 255, Default 207
ControlDisplay
Fc9-comp-macro.png ControlDisplay
Allows the display to be switched on and off
Fc9-u8-icon.png - BYTE Control
0=Off, 1=On
DrawArc
Fc9-comp-macro.png DrawArc
Draws an arc either as an outline or as a filled object.
Center X coordinate
Center Y coordinate
Radius, distance of edge from the centre coordinates
Fc9-f32-icon.png - FLOAT StartAngle
Angle to start drawing, in degrees
Fc9-f32-icon.png - FLOAT EndAngle
Angle to end drawing, in degrees
Fc9-u16-icon.png - UINT Resolution
Number of lines to draw from the center to the outer edge, 0=Fill
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
Fc9-u8-icon.png - BYTE Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawCircle
Fc9-comp-macro.png DrawCircle
DrawEllipse
DrawLine
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
DrawRectangle
Fc9-comp-macro.png DrawRoundedRectangle
Draws a rectangle with rounded corners
Fc9-comp-macro.png Initialise
InvertDisplay
Fc9-comp-macro.png InvertDisplay
Plot
Fc9-comp-macro.png Plot
Print
Fc9-comp-macro.png Print
Fc9-u8-icon.png - BYTE Font
Fc9-s16-icon.png - INT Number
ReadFontStat
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
SendCommand
Fc9-comp-macro.png SendCommand
Fc9-u8-icon.png - BYTE Command
SetBackgroundColour
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
SetDisplayOrientation
SetFontScaler
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
SetForegroundColour
0=White, 1=Black
Fc9-conn-icon.png Dimensions
Fc9-type-7-icon.png Interlaced
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-type-5-icon.png Reset Pin
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-type-21-icon.png Bytes Required
Number of bytes required in program memory to store the selected font.
Fc9-type-21-icon.png Character Spacing
Sets the number of blank pixels between each character when printing text.
Fc9-type-21-icon.png Space Width
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Component Label Scale
Fc9-type-16-icon.png Physical Orientation
Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
Please click here to download the component source project: FC_Comp_Source_GLCD_ST7036_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_ST7036_I2C.fcfx
