Component: Display Manager (Graphical Library)
Revision as of 14:13, 22 October 2025 by Wiki bot (talk | contribs)
Author MatrixTSL
Version 24.0
Category Graphical Library
Display Manager component
Version information
13, 2.0, 22-05-24, BR, Added text alignment options
14, 2.1, 14-06-24, BR, Renamed Button to Widget to better include things like sliders
15, 2.1, 26-07-24, BR, Added SetTextFloat and AddTextNumber macros
16, 2.1, 29-07-24, BR, Renamed Themes to ObjectThemes and WidgetThemes
17, 2.1, 29-07-24, BR, Added CreateTextField macro which automates creating a simple textbox
18, 2.1, 06-08-24, BR, Fixed a problem with updating values, theme, text on IDs
19, 2.1, 06-08-24, BR, Textfield now uses hidden object type instead of rectangle
20, 2.1, 06-08-24, BR, Fixed a problem where slider value could be set with out of range value
21, 2.1, 06-08-24, BR, Fixed problem where SetTextNumber would reset an ESP32
22, 22.0, 19-03-25, MW, Added keypad creation function
Objects
The component can create the following objects.
  • Object_Hidden - 0 - A hidden area with no graphics.
  • Object_Rectangle - 1 - A simple rectangular box.
  • Object_Line - 2 - A simple straight line.
  • Object_Ellipse - 3 - A simple ellipse or circle.
  • Object_EllipseFilled - 4 - A filled ellipse or circle.
  • Object_RectangeFilled - 5 - A filled rectangular box.
TextField
There is also an additional TextField object which consists of an Object_Rectangle that is pre-populated with text.
Widgets
The component can also create the following interactive buttons and sliders.
  • Widget_Hidden - 0 - A hidden area with no graphics.
  • Widget_Rectangle - 1 - A rectangular box with a shadow.
  • Widget_RoundedRectangle - 2 - A rounded rectangular box with a shadow.
  • Widget_Ellipse - 3 - A simple ellipse or circle with a shadow.
  • Widget_VSlider - 4 - A vertical slider with a square thumb.
  • Widget_HSlider - 5 - A horizontal slider with a square thumb.
  • Widget_VSlider_Round - 6 - A vertical slider with a round thumb.
  • Widget_HSlider_Round - 7 - A horizontal slider with a round thumb.
The type can be entered by using the component's public constants. Begin with the Display Manager handle name followed by :: and the list of the public variables will be displayed.
For example... DisplayManager1::Object_Rectangle or DisplayManager1::Widget_VSlider
Touch Repeat Rate for Button Widgets
The Touch Repeat Rate property applies to button based widgets and sets the frequency that a valid touch will be detected for a held button. This is similar to holding down a single key on a keyboard and acts to reduce the frequency of positive button detections when touching the button. For example if you had a button that incremented a value, without the repeat rate the value would increment much faster then anticipated in an uncontrollable manner. When no touch is detected it is recommended to call the NoTouch macro to clear the touch counters and allow a more responsive user experience.
Example of implementing touch repeat rate
Basic Example
An example showing how to use the display manager with a gLCD and a touch interface to create a full HMI.
FC6 Icon.png Display Manager Demo
Keypad Example
An example showing how you can use the CreateWigitArray component to create a touch keypad for your gLCD.
The CreateWidgetArray function macro has a number of parameters to allow high flexibility in what you can create:
There are also tooltips for each parameter to help.
Note: if you get a unable to run simulation error then make sure you have the latest components downloaded.
How the key touch is detected
The first widget is automatically assigned a unique widget ID e.g. the first widget with text 1 on it is assigned 24.
All the following widgets ID is then incremented from 24, e.g. widget with text 6 on is assigned 24+ 5 = 29.
The widget button pressed can then be calculated from 29 – 24 + 1 = 6.
FC6 Icon.png Display Manager Widget Array Keypad Example
CheckCollision
Fc9-comp-macro.png CheckCollision
Checks to see if two objects bounding boxes are colliding, Useful when implementing 2D games.
Fc9-u16-icon.png - UINT ID1
ID of Object or Widget to check
Fc9-u16-icon.png - UINT ID2
CheckForTouch
Fc9-comp-macro.png CheckForTouch
Uses the X and Y coordinates from a touch sensor to check for Widget presses. Returns 0 for no Widgets pressed. Returns ID for a valid Widget press. Any touched slider Widgets will automatically move their thumb and value to the touch position.
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
ClearAll
Fc9-comp-macro.png ClearAll
Removes all objects and Widgets from memory. Also clears the screen if required.
Fc9-bool-icon.png - BOOL ClearScreen
0=Don't clear the screen, 1=Clear the screen
CreateObject
Fc9-comp-macro.png CreateObject
Define a none touchable graphical object. Returns the Object ID.
Fc9-u8-icon.png - BYTE ObjectType
0=Hidden, 1=Rect, 2=RoundedRect, 3=Ellipse, 4=Line, 8=Bitmap
X Pixel Coordinate
Y Pixel Coordinate
Fc9-u16-icon.png - UINT Width
Pixel Width or X Radius
Fc9-u16-icon.png - UINT Height
Pixel Height or Y Radius
Fc9-u8-icon.png - BYTE LineWidth
Number of pixels thick to draw outer border lines
Fc9-u8-icon.png - BYTE Colours
Byte array containing FgColour RGB [0-2], Bg Colour RGB [3-5], Text Colour RGB [6-8]
Fc9-bool-icon.png - BOOL DrawObject
0=Do not draw object yet, 1=Draw object now (Does not apply to hidden objects)
CreateObjectArray
Fc9-comp-macro.png CreateObjectArray
Creates a 2d array of objects that can be used to create things like table data. Returns the ID of the first object, the following objects have incremental IDs going column by column and then row by row.
0=Hidden, 1=Rect, 2=Line, 3=Ellipse, 4=FilledEllipse, 5=FilledRect
Fc9-u8-icon.png - BYTE NumColumns
Number of columns of buttons in the array
Fc9-u8-icon.png - BYTE NumRows
Number of rows of buttons in the array
Fc9-u16-icon.png - UINT InitialPositionX
X location of the initial button
Fc9-u16-icon.png - UINT InitialPositionY
Y location of the initial button
Fc9-u16-icon.png - UINT ObjectWidth
Widget width in pixels
Fc9-u16-icon.png - UINT ObjectHeight
Object height in pixels
Fc9-u16-icon.png - UINT SpacingX
Horizontal spacing between the objects
Fc9-u16-icon.png - UINT SpacingY
Vertical spacing between the objects
Fc9-u8-icon.png - BYTE Font
Font used for the widgets text
Fc9-string-icon.png - STRING ObjectText
A comma seperated text field with the text for each object e.g. "1,2,3,.."
CreateTextField
Fc9-comp-macro.png CreateTextField
Creates a text field consisting of a rectangular border containing a single line of text
Text string to set as the label
X Pixel Coordinate
Y Pixel Coordinate
Pixel Width
Pixel Height
GLCD Font Index to use
Fc9-u8-icon.png - BYTE HAlignment
0=Left, 1=Center, 2=Right
Fc9-u8-icon.png - BYTE VAlignment
0=Top, 1=Middle, 2=Bottom
CreateWidget
Fc9-comp-macro.png CreateWidget
Define an interactive Widget or slider. Returns the Widget ID.
Fc9-u8-icon.png - BYTE WidgetType
0=WidgetHidden, 1=WidgetRect, 2=WidgetRoundedRect, 3=WidgetEllipse, 4=VSlider, 5=HSlider, 6=VSliderRound, 7=HSliderRound, 8=Bitmap
X Pixel Coordinate
Y Pixel Coordinate
Byte array containing FgColour RGB [0-2], Bg Colour RGB [3-5], Text Colour RGB [6-8], Hl Colour RGB [9-11]
Fc9-u8-icon.png - BYTE DrawHighlight
Draws the highlight on buttons, also used for thumb width on sliders
Fc9-bool-icon.png - BOOL DrawWidget
0=Do not draw Widget yet, 1=Draw Widget now (Does not apply to hidden widgets)
CreateWidgetArray
Fc9-comp-macro.png CreateWidgetArray
Creates a 2d array of buttons that can be used to create things like keypads. Returns the ID of the first button, the following buttons have incremental IDs going column by column and then row by row.
Fc9-u16-icon.png - UINT WidgetWidth
Fc9-u16-icon.png - UINT WidgetHeight
Widget height in pixels
Horizontal spacing between the widgets
Vertical spacing between the widgets
Fc9-string-icon.png - STRING WidgetText
A comma seperated text field with the text for each widget e.g. "1,2,3,.."
DrawAll
Fc9-comp-macro.png DrawAll
Redraws all of the defined Objects and Widgets. Doesn't draw text, this is done using the SetText macros.
DrawItem
Fc9-comp-macro.png DrawItem
Draws a single object or Widget onto the display without clearing the display. Doesn't draw text, this is done using the SetText macros.
Unique ID of the Object or Widget
DrawScene
Fc9-comp-macro.png DrawScene
Clears the screen and adds and draws the objects and widgets from the layout editor.
Fc9-u8-icon.png - BYTE SceneIndex
Select which screen to draw. Range: 0 to Scene Count - 1
GetLastTouchID
Fc9-comp-macro.png GetLastTouchID
Gets the ID of the last Widget that returned a valid press via the CheckForTouch macro. Returns 0 for no valid touch recorded.
Fc9-s16-icon.png - INT Return
GetSliderValue
Fc9-comp-macro.png GetSliderValue
Reads the value of one of the sliders ranging between 0 and 1.
Fc9-u16-icon.png - UINT WidgetID
Fc9-comp-macro.png Initialise
Initialises the object and Widget control variables and sets up the default themes.
ModifyBitmap
Fc9-comp-macro.png ModifyBitmap
Allows the bitmap image to be swapped out
Object or Widget ID to update
Bitmap filename in 8.3 file format
Fc9-bool-icon.png - BOOL Scaling
0=Native, 1=Stretch
Fc9-bool-icon.png - BOOL Transparancy
0=Disabled, 1=Enabled
Fc9-bool-icon.png - BOOL Redraw
ModifyColour
Fc9-comp-macro.png ModifyColour
Changes the theme index of the selected Object or Widget.
Unique ID of the object or Widget
Fc9-u8-icon.png - BYTE Index
0=Foreground, 1=Background, 2=TextColour, 3=Highlight(Widgets Only)
Fc9-u8-icon.png - BYTE R
Colour Channels
Fc9-u8-icon.png - BYTE G
Colour Channels
Fc9-u8-icon.png - BYTE B
Colour Channels
Redraws the component straight away in the new colours
ModifyPosition
Fc9-comp-macro.png ModifyPosition
Moves an existing object or Widget to absolute coordinates on the screen.
Fc9-s16-icon.png - INT X
Fc9-s16-icon.png - INT Y
Fc9-bool-icon.png - BOOL Relative
0=Absolute Positioning, 1=Relative Positioning
ModifyScale
Fc9-comp-macro.png ModifyScale
Changes the width and height of the selected Object or Widget.
NoTouch
Fc9-comp-macro.png NoTouch
Called when no touch is present, Allows the repeat rate counter to be cleared allowing for better responses to fast touches.
SetSliderValue
Fc9-comp-macro.png SetSliderValue
Sets the value of one of the sliders and optionally redraws the slider to reflect the value change.
Range: 0 to 1
Fc9-bool-icon.png - BOOL RedrawSlider
0=Do not redraw, 1=Redraw
SetTextLabel
Fc9-comp-macro.png SetTextLabel
Draws a single line of text onto an object or Widget location. Useful for labelling Widgets such as buttons or having name, value statistics. Drawn using the object themes.
Unique identifier of object or Widget.
Fc9-bool-icon.png - BOOL Transparent
0=Background Colour Drawn, 1=Don't Draw Background Colour
Fc9-type-16-icon.png Graphical Display
Graphical Display to draw our objects on
Fc9-type-16-icon.png DM Library
Display Manager compatible GLCD library component. e.g. Bitmap drawer components.
Fc9-type-21-icon.png Ram Usage Bytes
The calculated number of bytes of RAM required by the display manager.
Fc9-type-21-icon.png Text Align Offset
Number of pixels to move away from an edge when calling
Default background colour to use when clearing the display and applied as the default when creating new display creator scenes.
Fc9-conn-icon.png Objects
Fc9-type-21-icon.png Max Objects
The total number of primitive objects allowed on the screen at once. Sets the size of the RAM buffers used to track the various screen elements. Each object requires 10 bytes of RAM to stores things like size, location and type.
Fc9-conn-icon.png Widgets
Fc9-type-21-icon.png Max Widgets
The total number of touchable interactibe objects allowed on the screen at once e.g. Widgets and sliders. Sets the size of the RAM buffers used to track the various screen elements Each Widget requires 18 bytes of RAM to stores things like size, location, value and type.
Fc9-type-21-icon.png Touch Repeat Rate
Sets the period for touch repeats in terms of calls of the CheckForTouch macro. Widgets will only register a repeat touch after x calls if continually held down. Sliders will always register a touch. The touch count can be cleared using the NoTouch macro if no touch is detected.
Fc9-conn-icon.png Display Creator
Fc9-type-7-icon.png Enabled
Enable the display creator (WYSIWYG) scene panels.
Fc9-conn-icon.png Settings
Fc9-type-7-icon.png Enable Callbacks
Allows the widgets to define their own callback macros to simplify the act of processing touches
Fc9-type-21-icon.png Scene Count
Defines the number of invididual scene layout, display creator scenes available to draw
Fc9-conn-icon.png Scene Data
File:Fc9-type-26-icon.png Scene 0
