Component: Orientation ( Data)
Revision as of 15:40, 27 April 2026 by SteveT (talk | contribs)
Author MatrixTSL
Category Data
Orientation component
Component that provides orientation data for the mobile device using its internal magnetometer
Version information
1, 1.0, 24-04-26, ST, Created
Many mobile devices contain an internal accelerometer and magnetometer which together can report the orientation of the device.
This component allows access to this orientation data (if it is available on the device), returning with 3 angles showing the rotation of the device in the 3 axes (x, y and z).
Graphing the device orientation
This example shows the orientation of the device in the 3 axes on a chart.
DeviceOrientation.fcweb
The web app created by this example can be viewed here: DeviceOrientation Example
Using the Orientation component with a callback
The is a similar example to above, but this one uses a callback function to retrieve the orientation of the device whenever there is new data available.
DeviceOrientationWithCallback.fcweb
The web app created by this example can be viewed here: DeviceOrientationWithCallback Example
GetAlpha
GetAlpha
Returns rotation around the z-axis, i.e. twisted anticlockwise around the centre of the screen (in degrees between 0 and 360)
- FLOAT Return
GetBeta
GetBeta
Returns rotation around the x-axis, i.e. tilted forwards/backwards (in degrees between -180 and 180)
- FLOAT Return
GetGamma
GetGamma
Returns rotation around the y-axis, i.e. tilted left/right (in degrees between -90 and 90)
- FLOAT Return
Begins monitoring of the device's orientation information. Returns true if the device can provide orientation information.
- BOOL Return
IsAbsolute
IsAbsolute
Returns true if the device is providing absolute orientation information. Absolute data will be in reference to the Earth's coordinate frame.
- BOOL Return
Use Callback
Set true to use a callback that retrieves regular updates of the device orientation
Please click here to download the component source project: FC_Comp_Source_WEBEXP_Orientation.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_Orientation.fcsx
