Jump Icon Properties
Revision as of 16:06, 5 June 2026 by SteveT (talk | contribs) (Created page with "==Introduction== border|link= Jump icons are added to a Flowcode project macro to allow program execution to unconditionally jump to another location in...")
Introduction
Jump icons are added to a Flowcode project macro to allow program execution to unconditionally jump to another location in the macro.
In earlier versions of Flowcode, these were called "Connection Points" and the only type of jump supported was the "Goto" jump. Since v11.0.2, Flowcode now supports other types of unconditional jump: "Break", "Continue" and "Return".
Details
Display Name
Goto / Break / Continue / Return
The type of jump. More information on each jump type is below.
Jump to label
The label to jump to if using the "Goto" type of jump.
Jump Types
Goto
A "Goto" jump is used to link program flow from one part of a macro to another. To achieve this, the macro must already have a Label command icon. When program execution reaches the Jump command, it will unconditionally jump to the corresponding Label command that is set in the "Jump to label" dropdown.
Note: Using Jump::Goto commands is generally seen as bad programming practice and they should be avoided where possible. It makes projects more difficult to debug, and most well written programs will usually not need to use this icon.
Break
A "Break" jump prematurely exits a Loop or Switch command. Program execution will continue with the command immediately after the end of the Loop or Switch that contains the "Break" jump command.
It must occur within a Loop or Switch command, otherwise an error will occur. If it is contained within multiple 'levels' of Loop or Switch commands, it will jump out of the inner-most command.
Continue
A "Continue" jump prematurely exits the current iteration of a Loop. If the Loop's test remains true, the next iteration of the Loop will be performed. Otherwise, program execution will exit the Loop and continue with the command directly following the end of the Loop.
A 'Return' jump command can be located anywhere in a macro. When the program executes this command, it will immediately exit the current macro and will not execute any other code in the macro. If this macro returns a value, the current value of the return variable is returned.
Video
See the Jump icon video to see how this icon can be used in your Flowcode projects.
