Component: DAC Quad (MCP4728) (MCP4728) (Analog Output)
Revision as of 13:09, 7 February 2023 by Wiki bot (talk | contribs)
Category Analog Output
DAC Quad (MCP4728) component
Component to drive a quad digital to analogue converter (DAC) IC from Microchip via an I2C interface. Compatible with MCP4728 (12-Bit) devices.
Please click here to download the component source project: FC_Comp_Source_DAC_MCP4728.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DAC_MCP4728.fcfx
ControlPins
Fc9-comp-macro.png ControlPins
Allows Shutdown (SHDN) and Latch (LDAC) pins to be controlled directly if enabled.
Fc9-bool-icon.png - BOOL Latch
0 = Data output driven from DAC register, 1 = Data output locked
Disable
Fc9-comp-macro.png Disable
Disables the DAC output.
Range: 0-3 / 0=DAC Channel 0 / 1=DAC Channel 1 ...
Enable
Fc9-comp-macro.png Enable
Enables the DAC Output.
Fc9-comp-macro.png Initialise
Configures the SPI peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated.
SetDeviceAddress
Fc9-comp-macro.png SetDeviceAddress
Writes a new device address into EE memory. The use LDAC pin component property must be set to true and the LDAC pin should be unique for every MCP4728 device connected to the I2C bus.
Fc9-u8-icon.png - BYTE OldAddress
Range: 0-7
Fc9-u8-icon.png - BYTE NewAddress
Range: 0-7
SetInitialEEOutput
Fc9-comp-macro.png SetInitialEEOutput
Stores a DAC value into EE memory to be used on power up.
Fc9-u16-icon.png - UINT DAC_Value
The value to output to the DAC
SetOutput
Fc9-comp-macro.png SetOutput
Sets the output voltage of the DAC 12-Bit: Range 0-4095
Fc9-type-16-icon.png Pull Down Option
Fc9-type-16-icon.png VREF Option
Fc9-type-16-icon.png Gain Option
Fc9-type-15-icon.png Vref Voltage
Fc9-type-21-icon.png Steps
Number of discrete output states available from the DAC.
Fc9-type-14-icon.png Control Bits
Fc9-type-10-icon.png Resolution
Fc9-type-15-icon.png Voltage Resolution
Fc9-conn-icon.png I2C Connections
Fc9-type-16-icon.png Device Address
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-type-7-icon.png Use LDAC Pin
Allows the LDAC pin to be driven from an output pin on the microcontroller. If not used then tie the LDAC pin to GND to allow the DAC to function.
Fc9-conn-icon.png Simulation
Fc9-type-7-icon.png Simulation Comms
