API Panel.PCloud.UnitScale
Revision as of 11:54, 16 January 2023 by Wiki bot (talk | contribs)
UnitScale
Creates a unit scaled axis (X, Y or Z) with a center of zero and a range of two
- FLOAT[] Axis
The X, Y or Z axis to adjust
- ULONG Offset
The first item in the array to adjust
- LONG ArrayStep
The number of elements from the first to the second
- ULONG Elements
The number of points to adjust
- FLOAT OrigOffset
Returns the center of the original object
- FLOAT OrigRange
Returns the range of the original object
- NONE Return
  • Add to a calculation icon:
    ::Panel.PCloud.UnitScale(_arrayaxis, offset, arraystep, elements, return_origoffset, return_origrange)
