API Console.GetLineBytes
Revision as of 11:55, 16 January 2023 by Wiki bot (talk | contribs)
GetLineBytes
Reads a line of bytes from the given console extending the array if needed
- HANDLE ConsoleHandle
A valid console windows handle
- ULONG Line
The zero-based index of the line to read the data from, pass -1 for final line
- BYTE[] Buffer
A buffer to read the data into
- ULONG Offset
An offset into Data of the first byte to write to
- ULONG MaxBytes
The number of bytes to read, -1 for full line
- ULONG Return
  • Declare a variable 'result' of type ULONG
  • Add to a calculation icon:
    result = ::Console.GetLineBytes(consolehandle, line, _arraybuffer, offset, maxbytes)
